octopusprime314
sp605 red leds
I get the error program fail when using impact ISE.
The error log reads...
write cmdbuffer failed 20000015.
Error reading reference voltage level.
Also the INIT LED is red and the DS18 LED is red.
Any suggestions?
smarell
Community Manager
Community Manager
The error occurs when the USB circuitry has gone bad. To confirm this, please try to configure another board. As a workaround, you can use the JTAG flying leads to configure the FPGA.
octopusprime314
I thought those 6 flying leads were gpio.  Are you talking about the 6 pins that are located very close to the jtag/uart ports?  If not could you tell me where those leads exist?
rlewis65
Yes, the 6 pins next to the USB JTAG and Serial connectors.
I like these books:
Free Range VHDL (free), http://www.freerangefactory.org/site/pmwiki.php/Main/Books
VHDL for Logic Synthesis, Andrew Rushton
FPGA Prototyping by VHDL Examples, Pong P Chu
octopusprime314
I have attached a schematic of the J55 port located near the JTAG/UART connects.
It seems to me that these pins aren't for JTAG and if they are then the documentation isn't so descriptive as to why they are for JTAG.
One other thing is that I have never understood what those filled in triangles mean that are found at the first or last pins on a port like J55.  Does that mean ground or does it signify the first or last pin?JTAG.jpg
octopusprime314
Do i need to change the configuration of how the FPGA is programmed now that I have bypassed the usb?
I am getting this error log...
INFO:iMPACT - Failed to open file: -- File ? --, replace with 'bypass'.
INFO:iMPACT:1777 -
Reading C:/Xilinx/13.4/ISE_DS/ISE/acecf/data/xccace.bsd...
INFO:iMPACT:501 - '1': Added Device xccace successfully.
'2': Loading file 'dvi_memory.bit' ...
done.
INFO:iMPACT:1777 -
Reading C:/Xilinx/13.4/ISE_DS/ISE/spartan6/data/xc6slx45t.bsd...
INFO:iMPACT:2257 - Startup Clock has been changed to 'JtagClk' in the bitstream stored in memory,
but the original bitstream file remains unchanged.
UserID read from the bitstream file = 0xFFFFFFFF.
Data width read from the bitstream file = 1.
INFO:iMPACT:501 - '2': Added Device xc6slx45t successfully.
Active mode is BS
'2': Loading file 'C:/School/ELE_480/DVI_Pass_Through/vhdl/ise_sp605/dvi_memory.bit' ...
done.
GUI --- Auto connect to cable...
INFO:iMPACT - Digilent Plugin: found 1 device(s).
INFO:iMPACT - Digilent Plugin: opening device: "DCabUsb", SN:50003D123456
INFO:iMPACT - Digilent Plugin: User Name: DCabUsb
INFO:iMPACT - Digilent Plugin: Product Name: JTAG-USB Cable
INFO:iMPACT - Digilent Plugin: Serial Number: 50003D123456
INFO:iMPACT - Digilent Plugin: Product ID: 30100203
INFO:iMPACT - Digilent Plugin: Firmware Version: 0303
INFO:iMPACT - Digilent Plugin: JTAG Port Number: 0
INFO:iMPACT - Digilent Plugin: JTAG Clock Frequency: 1600000 Hz
INFO:iMPACT - Current time: 2/22/2013 8:31:13 AM
PROGRESS_START - Starting Operation.
INFO:iMPACT:583 - '2': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '2': Device IDCODE : 00000000000000000000000000000000
INFO:iMPACT:1579 - '2': Expected IDCODE: 00000100000000101000000010010011
PROGRESS_END - End Operation.
Elapsed time = 0 sec.
amandaw
The filled-in triangle signifies pin 1.  You can verify this by looking at the pads on the backside of the board and comparing them with the information in AR #41818
In addition, there is no external access header for JTAG on the SP605.
