spartan 3e cable detection failed
IMPACT showing cable detection failure for my digilent spartan 3E board.  I  was using another diglent board before and it is detecting cable. Below provided is the failure message shown in IMPACT.  What may be the problem? Please help.
GUI --- Auto connect to cable...
INFO:iMPACT - Digilent Plugin: Plugin Version: 2.2.10
INFO:iMPACT - Digilent Plugin: no JTAG device was found.
AutoDetecting cable. Please wait.
PROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
Driver file xusb_emb.sys found.
Driver version: src=1029, dest=1029.
Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021.
Cable PID = 0008.
Max current requested during enumeration is 74 mA.
write cmdbuffer failed 20000015.
Loopback test failed. Sent character = 00, Received character = 09.
Cable connection failed.
Connecting to cable (Parallel Port - LPT1).
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
PROGRESS_END - End Operation.
Elapsed time = 8 sec.
Cable autodetection failed.
WARNING:iMPACT:923 - Can not find cable, check cable setup !
Re: spartan 3e cable detection failed
Did you check this answer records: http://www.xilinx.com/support/answers/31931.htm
http://www.xilinx.com/support/answers/24911.htm
Vinay
Community Manager
Community Manager
This answer record can be of great help in resolving cable detection issues- http://www.xilinx.com/support/answers/30184.html
Krishna
In your post you mentioned that "IMPACT showing cable detection failure for my digilent spartan 3E board.  I  was using another diglent board before and it is detecting cable".
The above input indicating me that there could not be problem a in cable or cable driver. There could be some problem in board configuration part hardware. Please verify  jumpers and switch settings as per user guide. Also check supply voltages as per data sheet recommendations.
If possible probe JTAG signals.
Hi Kodali,
thank you. I checked jumper settings, it iscorrect. I compared the log file of cable sucessfullyconnecting and not connecting spartan 3e boards. Where I noticed in cable not connecting board showing " write cmdbuffer failed 20000015 " error. What is the reason for that? I am attaching both log files here with. Can you Plaese have a look on it
thanks
kathy
Hi Kathy,
check if the following AR helps
--Kirshna
This error occurs when the USB circuitry has some problem (Probable root cause). If you have spare board please try to configure another board to confirm this.
As a workaround, if possible try to use the JTAG flying leads to configure the FPGA.
I am too facing the same problem, Just today. Is there any solution to this. I am using Spartan 3AN and Linux platform.
Hi THIYAGARAJAN,
From the snapshot, I can say that the issue is cable driver installation. Reinstall cable drivers. As mentioned in the message, see the answer record: http://www.xilinx.com/support/answers/22648.html
Vinay
