eitanbella
spartan6 readback of blockRAM RAMB16BWER
hi,
I'm trying to do readback of spartan6 ( xc6slx9 ) block ram.
I implemented in my design units of RAMB16BWER.
the Impact program generated *.ll file (logic allocation file) which should describe the location of the Block-Ram bits on the readback file.
this *.ll file looks starnge:
It looks like SEVERAL bits in the Block-Ram (and not single bit) are located on THE SAME position (=offset) from the readback file.  Which is not logical!
Another strange behaviour: the frames of the BlockRams start from a bit index on the readback file which is bigger than
the actual size of the readback file maximum bit index.
Can anyone help me understand what I doing wrong and how can i get the real value of the BlockRam bits from the logic allocation file????
thanx'
eithan
austin
I believe there are a number of issues with readback of the BRAM in S6: check the technical answers.
http://www.xilinx.com/support/answers/32651.htm
Austin Lesea
Principal Engineer
Xilinx San Jose
eitanbella
hi again'
the issues on the attached link - are irrelevant to my problem.
i use write_first mode and RAMB16BWER on spartan6.
when i create the logic allocation file (*.ll) from which i want to extract the location of SINGLE bit  from the block ram on my impact.bin file. i get texts like (copied from my *.ll file):
Bit  2325678 0x1100c236    306 Block=RAMB16_X0Y14 Ram=B:BIT9056
Bit  2325678 0x1100c237    288 Block=RAMB16_X0Y14 Ram=B:BIT9073
Bit  2325678 0x1100c238    270 Block=RAMB16_X0Y14 Ram=B:BIT9090
Bit  2325678 0x1100c239    252 Block=RAMB16_X0Y14 Ram=B:BIT9107
Bit  2325678 0x1100c23a    234 Block=RAMB16_X0Y14 Ram=B:BIT9124
Bit  2325678 0x1100c23b    216 Block=RAMB16_X0Y14 Ram=B:BIT9141
Bit  2325678 0x1100c23c    198 Block=RAMB16_X0Y14 Ram=B:BIT9158
Bit  2325678 0x1100c23d    180 Block=RAMB16_X0Y14 Ram=B:BIT9175
Bit  2325678 0x1100c23e    162 Block=RAMB16_X0Y14 Ram=B:BIT9192
Bit  2325678 0x1100c23f    144 Block=RAMB16_X0Y14 Ram=B:BIT9209
Bit  2325678 0x1100c240    126 Block=RAMB16_X0Y14 Ram=B:BIT9226
Bit  2325678 0x1100c241    108 Block=RAMB16_X0Y14 Ram=B:BIT9243
Bit  2325678 0x1100c242     90 Block=RAMB16_X0Y14 Ram=B:BIT9260
In this example of the *.ll file:
what bit from the BLOCK RAM will be in offset 2325678 from the impact.bin?
It seems like many BLOCKRAM bits are there!!!
can you tell me what should i do in order to know how to do readback of block rams.
ASAP
thanx
eitan
robinliuy
Voyager
Voyager
The .ll format is
<offset> <frame address> <frame offset> <information>
eitanbella
hi again'
I know the *.ll format and that it starts with the offset from the readback file.
but it seems theres a BUG in the *.ll file:.
to make you understand the BUG, i copied a part of my ll file:
a) Where is the location for Bit9260 of the RAM BLOCK?
    its on offset (from readback file) = 2325678 according to the ll file.
b) Where is the location for Bit9243 of the RAM BLOCK?
    its also (!) on offset (from readback file) = 2325678 according to the ll file.
c) Where is the location for Bit9226 of the RAM BLOCK?
    its also (!!!) on offset (from readback file) = 2325678 according to the ll file.
etc...
How is it possible???  Is the a BUG in the *.ll on spartan6???
Eitan
