which software should I use for spartan XCS30
I downloaded webpack 4.1 and 4.2, and  found a folder named "spartan" after software installed, but when I creat a new project, it only gives the option to choose spartan2 and spartan2E families. Webpack 3.3 always give me problem when installing on windows XP. so which software I can use to compile an old project for XCS30? thanks a lot.
The last version of softwaresupporting this original Spartan FPGA family is ISE®4.2, which isavailable for download as “ISE Classics”inthe following location:
Thanks and Regards
Balkrishan
Hi @haiqings
Check this answer record: http://www.xilinx.com/support/answers/15938.html
Vinay
