Indirect SPI Programming Failed
I am having trouble programming using iMPACT the XC3S200A with a W25X40CL flash chip. I am using Indirect SPI Programming and below is my error log.
Thank you for your help,
David
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable operations.
INFO:iMPACT - Downloading core file C:/Xilinx/14.7/ISE_DS/ISE/spartan3a/data/xc3s200a_spi.cor.
'1': Downloading core...
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Reading status register contents...
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0000 0000 0000 0000
INFO:iMPACT:2492 - '1': Completed downloading core to device.
INFO:iMPACT - '1': Flash was not programmed successfully.
PROGRESS_END - End Operation.
Elapsed time = 0 sec.
Re: Indirect SPI Programming Failed
Hi @davidgoldy91,
It seems there is some hardware issue on the SPI interface, and the device code is not checked at all.
Simon
Hi @simon
Thanks so much for your reply.
I set the XIL_IMPACT_SKIPIDCODECHECK to 1 since the flash chip I'm using (W25X40CL) isn't listed by iMPACT.  Maybe that is the reason why this issue is appearing? The W25X40CL should be functionally identical to the M25P40 flash chip. Would you advise setting this flag to 0? The FPGA itself programs successfully but the indirect programming of the SPI flash seems to fail outright.
Thank you again,
David
Hi @davidgoldy91,
As a test, you can Set XIL_IMPACT_SKIPIDCODECHECK to 0 to see what the log is?
Simon
