Visitor yere1
LVDS in spartan 6 XC6SLX45, package CSG324
I'm trying to get ANY signal on the HDMI output in J2. I use the code below, but cannot see anything when scoping (it's all 0v).
Below is my module and ucf:
Module:
module YE_spartan6_v002(
	//--General
	input CLK_IN1,
	//--ASK
	output oASKp,
	output oASKn
	OBUFDS OBUFDS_inst (
		.O(oASKp), // 1-bit output: Diff_p output (connect directly to top-level port)
		.OB(oASKn), // 1-bit output: Diff_n output (connect directly to top-level port)
		.I(1) // 1-bit input: Buffer input
endmodule
.ucf file:
# CLK
NET "CLK_IN1" LOC = L15;
# ASK
# PlanAhead Generated IO constraints
NET "oASKp" IOSTANDARD = LVDS_25;
# PlanAhead Generated physical constraints
NET "oASKp" LOC = C7;
NET "oASKn" LOC = A7;
Am I doing something wrong?
Re: LVDS in spartan 6 XC6SLX45, package CSG324
Do you have a terminating resistor between the p and n signals?
Visitor yere1
Yes I'm using a terminating resistor.
Community Manager
Community Manager
As the input to the OBUFDS is 1 I'm wondering if ISE has removed it?
If you look in FPGA Editor is the OBUFDS still there?
What else is in the bank with the oASKp/n pins? Are they behaving as expected?
as @sandrao mentions, the SW could have removed it. Have a look at the NCD file to verify the '1' is still there, you could also try adding a VIO from chipscope to allow you to control it. or you could route a pushbutton from an input to the output you are trying to measure
