Observer c_oflynn
Non-Dedicated Clock Input Pin to DCM: Why is this Bad?
I'm trying to build a small add-on board for the Avnet S6 LX9 Microboard. This board has two extension headers - but neither of them have a GCLK input pin.
My board will take a clock input signal (range about 16-64 MHz), pass it through a DCM, and use that signal to clock an external ADC & internal BRAM-based FIFO. The DCM will be used for both frequency synthesis (4x clock mul) along with dynamic phase adjustment.
I don't care about the absolute phase relationship between source clock & output of DCM. I'll be adjusting the phase with the DCM anyway to line up ADC samples with events occurring on the external clock. Once the samples are lined up I want that phase relationship to remain constant.
So - what is the actual downside of using a generic input pin instead of GCLK pin? I haven't been able to find much detail in why doing this is bad, just that it is. I'd like to get an idea if I should start looking for alternative hardware, or if I will be able to get away with what I currently have planned. Does it mean increased jitter, less predictable delay with voltage/temp change, etc? Some downsides I can live with in my application, but I don't even know what they are exactly!
    -Colin
Scholar austin
Re: Non-Dedicated Clock Input Pin to DCM: Why is this Bad?
Colin,
If you do not care about absolute phase, then there is no problem.
The IBUF, dedicated clock pin route has a controlled, known delay (for the tools), and a general IO pin, using hte regular fabric interconnect will have a delay that varies more, but is really no different in performance, than the dedicated route.
It is true that if you used regular interconnect for all of your clock routing, you could have more jitter, but the short path from IOB to the nearest global buffer access point (or DCM), is not enough of a span to introduce jitter.  By choosing the same resources for the DCM feedback path, you may actually compensate for the variations.  This may require hand placement of hte routes in FPGA_editor, but could provide a better solution (at some cost of time and effort, and future maintainability).
You will get a warning, or more than one warning, which you may ignore.
The delay will change with process (chip to another chip), voltage, and temperature;  but then, it would do so for the IBUF as well.  The use of the BUFG for the DCM feedback is designed to compensate for this.  If you are not pushing the performance too far, you will be able to choose a fixed delay sampling point.  Otherwise you will have to have a sort of training sequence to find the best spot to sample for each board, and perhaps re-calibrate if the voltage/temperature changes (like what is done for the DDR memory devices at very high speeds).
Austin Lesea
Principal Engineer
Xilinx San Jose
Scholar austin
Colin,
Austin Lesea
Principal Engineer
Xilinx San Jose
Observer c_oflynn
Hi Austin, Thanks for the information - that is basically exactly what I was hoping to hear! The variance with device/temperature/voltage isn't an issue, as the recalibration would be occurring for different inputs to the module anyway. It was only jitter I was really worried about, and it sounds like in my case that either won't be an issue or something I can manage with minimal effort. Warm Regards, -Colin O'Flynn
I do this many times, to use non gclk pin for input clock
IMO, the internal routing from general IOB to the dedicate buffer GBUF is still better than the its trace/segments on the PCB.
For some reason my boards end up with zig-zac trace on the clock net that feeds into the FPGA... When I talk to the board development's, I've got the answer  for "data & clock matching length" ???  But I always have to calibrate the clock phase to meet timing at the IOB
Observer c_oflynn
A little nerd porn... completed ADC board with variable gain amplifier (~10-40dB gain), should make that cheap Avnet board handy for interfacing with the real world! ADC Board (Newae.coM)
Newbie gaurav7931
May i know how much delay is introduced, from non-clk pin to global buffer.??
