Visitor mkjaswal
Place & Route- DRC WARNING:PhysDesignRules:372 - Gated clock.
WARNING:PhysDesignRules:372 - Gated clock. Clock net cam_2/clk_n is sourced by a
   combinatorial pin. This is not good design practice. Use the CE pin to
   control the loading of data into the flip-flop.
But the statement simple says assign clk_n = !clk;
whr both clk and clk_n are used in different modules separately.
What is the issue then.. how to create a clk_n in a correct way then????
MKJ
Re: Place & Route- DRC WARNING:PhysDesignRules:372 - Gated clock.
You can clock a flip flop in an FPGA from either the rising or falling edges.   There are few reasons to try to invert the clock.  If you must, the DCM or a PLL should allow you to create a new clock with the desired phase shift.
Visitor mkjaswal
thanks for your response,
to generate a negated clk, i now use a negative edge triggered flip flop.
Firstly :  why this issue doesnot occur when the clock is generated from clk_divider logic like follows?? is it becoz, it is the flip flop generating the divided clock??
initial // <=  works in xilinx
begin
b=2'b0;
o_clk=1'b0;
end
always@(posedge clk)
begin
b<=b+2'b1;
o_clk<=b[1];
end
Secondly the warning regarding Gated clock & combinatorial pin is also as below:
PhysDesignRules:372 - Gated clock. Clock net cam_2/m1/_n1251 is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to control the loading of data into the flip-flop.
cam_2/m1/_n1251 signal is generated by synthesis tool through LUT4, and doesnt exist in my verilog code, as can be checked in the post synthesis verilog file. I dont even know what I0, I1, I2 and I3 are, might require lot a back tracing, which might not a good debugging practice for a huge design.
I agree that a this portion of the code is generated through CASE statement, which is a combinational logic, but using case statement (with a default case) is also a valid verilog practice, isnt it??
LUT4 #(
.INIT ( 16'h4555 ))
\cam_2/m1/_n12511 (
.I0(\cam_2/m1/en_r_sel[33]_GND_6_o_equal_3_o ),
.I1(o_sel_9_OBUF_67),
.I2(\cam_2/m1/en_r_sel[33]_GND_6_o_equal_3_o<33>1 ),
.I3(\cam_2/m1/en_r_sel[33]_PWR_6_o_equal_29_o<33>2 ),
.O(\cam_2/m1/_n1251 )
Same applies to PhysDesignRules:372 - Gated clock. Clock net icon_control0<13> is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to control the loading of data into the flip-flop.
I dont even know which net is icon_control0<13>. In case it is linked to chipscope in any way, i have generated chipscope through .cdc file , where there are only trigger ports visible and no icon_control0<13>.
How to trace the cause of such Gated Clock - combinatorial issues????
Thanks in advance..
MKJ
