Accepted Solution
Spartan6 Suspend-Pin unconnected
Re: Spartan6 Suspend-Pin unconnected
Here is the initial webcase response:
As you mentioned, UG380 states that the SUSPEND pin must be tied LOW for configuration. If this requirement is not respected the memory cell array may not be initialized correctly. Random data in the configuration memory, causes contentions.  It is important to ensure the SUSPEND pin is low during power up and configuration.
  • If the SUSPEND pin is left floating and if the bitgen option is enabled, there is the possibility that the FPGA will enter into SUSPEND mode.
  • If the SUSPEND pin is left floating and if the bitgen option is disabled, I would expect that the FPGA will not enter SUSPEND mode as the SUSPEND pin will be ignored. You should not be able to accidentally enter into a Suspend mode if the pin floats, but you will have other power and noise implications on the pin.
We have not characterised behaviour other than SUSPEND being tied LOW for power-on and configuration, as this is our recommendation, and so, we cannot guarantee the behaviour if SUSPEND = 1 at power-on.  Therefore, it is difficult to predict what will happen.
-- Bob Elkind
SIGNATURE:
Summary:
I have patched my 6-layer-board (mill the board from rear side till the ball of FPGA) and connect the suspend-pin to GND. But the FPGA don't configure.
So I have inspected everything over again and have found my mistake. One mode-pin was not connected properly!
Thanks all for help!
Congratulations on finding the error.
Nice photograph!
-- Bob Elkind
SIGNATURE:
Summary:
I suggest that you glue all modification wires to the PCB to reduce the risk of them becoming detatched.
"If it don't work in simulation, it won't work on the board."
Instructor
Just a note for next time you need to debug this sort of problem:
Impact allows you to view the state of the configuration pins.  You should have been
able to see the state of the mode pins as seen by the internal logic just by using
one of the debug functions of Impact.  Especially with BGA's this is a valuable tool.
When I design a board with BGA's I typically require the layout designer to place a
via for each unconnected pad just in case I find I needed to make a connection.
It helps you to avoid the sort of rework you show in your nice picture.
-- Gabor
-- Gabor
