Work Around for MIG for Spartan 6 TQG144 package
I recently purchased a board that came with a xilinx spartan 6 XC6SLX9 TQG144 package and a 256MBIT SDRAM, I've tried using the MIG core generator, but it seems that the TQG144 package is not supported, and reading through the user guide revealed that this package has 0 MCBs; is there any work around to this problem (Or did the board manufacturer make a big mistake by putting the SDRAM on the board)?.
Tags (3)
Scholar u4223374
Re: Work Around for MIG for Spartan 6 TQG144 package
I'd probably have a look over on OpenCores. First result I found: 16-bit SDRAM controller. That one has been tested on the XC6SLX9, so it looks like an ideal place to begin.
Scholar u4223374
The MCB doesn't support standard SDRAM anyway; only DDR/DDR2/DDR3. It's used for these interfaces because they need performance higher than the programmable logic can provide - at least without a huge amount of very careful tuning.
For standard SDRAM running at maybe 100MHz, the programmable logic is quite fast enough to do what you need. However, you do need to write a memory controller to utilize it.
Thank you for your reply... I was wondering if there was anywhere you could point me to as creating a custom controller In my case
Scholar u4223374
Thank you very much, I'm so grateful
