Newbie brimacroru
driving clock on IO
I'm using spartan6 LX100 fg676.
What is the correct way to use clock output from pll that should drive internal logic and be output from fpga?
Currently i'm connecting the output CLKOUT2 of the PLL_adv to a bufg cell that is driving both the internal logic and IO's.
I'm getting the following warning in P&R.
What is the correct way to do this?
< PIN: sd1_ck[4].O; >
   This design practice, in Spartan-6, can lead to an unroutable situation due
   to limitations in the global routing. If the design does route there may be
   excessive delay or skew on this net. It is recommended to use a Clock
   Forwarding technique to create a reliable and repeatable low skew solution:
   instantiate an ODDR2 component; tie the .D0 pin to Logic1; tie the .D1 pin to
   Logic0; tie the clock net to be forwarded to .C0; tie the inverted clock to
   .C1. This is normally an ERROR but the CLOCK_DEDICATED_ROUTE constraint was
   applied on COMP.PIN <mig_project/memc1_infrastructure_inst/U_BUFG_CLK0​.O>
   allowing your design to continue. This constraint disables all clock placer
   rules related to the specified COMP.PIN.
WARNING:cattongue:lace:1137 - This design is not guaranteed to be routable! This design
   contains a global buffer instance,
   <mig_project/memc1_infrastructure_inst/U_BUFG_CLK0​>, driving the net,
   <c1_clk0>, that is driving the following (first 30) non-clock source pins.
   < PIN: sd1_ck[0].O; >
   < PIN: sd1_ck[1].O; >
   < PIN: sd1_ck[2].O; >
   < PIN: sd1_ck[3].O; >
   < PIN: dphy_pif/dphy_pif_host_if/pif_cdiv/scan_mux/Y_i_m3​.A1; >
   This is not a recommended design practice in Spartan-6 due to limitations in
   the global routing that may cause excessive delay, skew or unroutable
   situations.  It is recommended to only use a BUFG resource to drive clock
   loads. Please pay extra attention to the timing and routing of this path to
   ensure the design goals are met. This is normally an ERROR but the
   CLOCK_DEDICATED_ROUTE constraint was applied on COMP.PIN
   <mig_project/memc1_infrastructure_inst/U_BUFG_CLK0​.O> allowing your design to
   continue. This constraint disables all clock placer rules related to the
   specified COMP.PIN.
Teacher eteam00
clock forwarding
Here is an example of clock forwarding to a package output, from UG382, Figure 3-13:
You can find a Verilog template (example code) for the clock forwarding circuit from within the ISE Navigator shell.
Click on the <lightbulb> icon to bring up the Language Templates pane.  From within this pane, select:
Verilog > Synthesis Constructs > Coding Examples > Misc > Output Clock Forwarding Using DDR
-- Bob Elkind
SIGNATURE:
Summary:
Visitor nickagian
Re: clock forwarding
Hi!
I found this topic since I had the same problem in my case. Could I ask two questions on this, though?
(1) I indeed implemented it as recommended. However, I still get a similar error during synthesis
ERROR:Place:1136 - This design contains a global buffer instance,
   <ethPLL_1/clkout1_buf>, driving the net, <Clk125MxC>, that is driving the
   following (first 30) non-clock load pins.
   < PIN: Clk125MxC_INV_7_o1_INV_0.A6; >
   loads. If you wish to override this recommendation, you may use the
   CLOCK_DEDICATED_ROUTE constraint (given below) in the .ucf file to demote
   this message to a WARNING and allow your design to continue.
   < PIN "ethPLL_1/clkout1_buf.O" CLOCK_DEDICATED_ROUTE = FALSE; >
So, essentially, the Clk125MxC signal is the clock signal before the ODDR2. As you can see, it still produces some problem. Is it safe to put this constraint in the .ucf file as recommended? What are the disadvantages of this?
(2) Another thing I don't understand is the following: The Clk125MxC is essentially used as the TX clock for a GMII interface, between the FPGA and an external PHY device. This means that data output lines and the TX_EN signals should be syncrhonized with this clock. However, the way I see it the data are now clocked inside the FPGA with the Clk125MxC but the clock coming out is being delayed by the FF-delay. Isn't that a problem? Is there any way to overcome this?
Thank you, Nikos
Teacher eteam00
What FPGA device family are you targeting?
Please post the code which infers or instantiates the ODDR (or ODDR2) output registers.  The error message suggests that the output of a global clock buffer is used to drive ordinary (non-clock) logic.
It would help to see your implementation code, to understand precisely your concern.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor nickagian
Yes, sorry for not mentioning the FPGA. It's a Spartan-6 XC6SLX45T.
-- ethernet PLL instantiation
  ethPLL_1: ethPLL
    port map (
      ClkInxCI  => Clk100MxC,
      ClkOutxCO => Clk125MxC,
      ResetxRI  => ResetxR,
      LockedxSO => EthPllLockedxS);
  -- Clock forwarding circuit using the double data-rate register
   --        Spartan-3E/3A/6
   -- Xilinx HDL Language Template, version 13.2
   ODDR2_inst : ODDR2
   generic map(
      DDR_ALIGNMENT => "NONE", -- Sets output alignment to "NONE", "C0", "C1"
      INIT => '0', -- Sets initial state of the Q output to '0' or '1'
      SRTYPE => "SYNC") -- Specifies "SYNC" or "ASYNC" set/reset
   port map (
      Q => GmiiGTxClkxCO, -- 1-bit output data
      C0 => Clk125MxC, -- 1-bit clock input
      C1 => not Clk125MxC, -- 1-bit clock input
      CE => '1',   -- 1-bit clock enable input
      D0 => '0',   -- 1-bit data input (associated with C0)
      D1 => '1',   -- 1-bit data input (associated with C1)
      R => ResetxR,-- 1-bit reset input
      S => '0'     -- 1-bit set input
So here is the code that instantiates the ODDR2. ethPLL takes 100MHz and produces 125MHz that is used both internally to clock the ethernetTx.vhd block (look below) and externally to the 88E1111 Marvell PHY IC. So I'm using the ODDR2 and the GmiiGTxClkxCO goes directly to the output pin. The internal block uses the Clk125MxC signal (Perhaps this is my mistake? I don't know...)
The Clk100MxC clock comes from another PLL which previously converts the input 200MHz diff oscillator signal to some other useful frequencies (actually I am using an SDRAM memory controller that needs 800MHz clock). The reason that I don't use only one PLL is that I cannot create the desired 125MHz and the 800MHz from the same primitive.
Now, regarding my other concern. Here is the ethernetTx block that sends ethernet frames.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
library work;
use work.multiTouchPkg.all;
use work.crc32Pkg.all;
entity ethernetTx is
  port (
    -- Clock and Reset signals
    ClockxCI            : in  std_logic;     -- Input clock
    ResetxRBI           : in  std_logic;     -- Active low reset
    -- Status signals
    BusyxSO             : out std_logic;  -- Asserted when TX is in progress
    -- Ethernet TX FIFO Read Interface
    FifoDataOutxDI      : in  std_logic_vector(7 downto 0);  -- Data from the FIFO
    FifoEmptyxSI        : in  std_logic;  -- Empty signal
    FifoRdEnxSO         : out std_logic;  -- Read enable signal
    FifoRdCntxDI        : in  std_logic_vector(11 downto 0);  -- Read data counter
    -- Ethernet PHY Tx Interface
    GmiiGTxClkxCI       : in  std_logic;        -- TX clock 125MHz
    GmiiTxEnxSO         : out std_logic;        -- TX enable
    GmiiTxErxSO         : out std_logic;        -- TX error
    GmiiTxDataxDO       : out std_logic_vector(7 downto 0)  -- TX data
end ethernetTx;
-- Architecture
architecture behavioral of ethernetTx is
  -- Components
  component crcGenerator
    port (
      NewFramexSI   : in  std_logic;
      DataInxDI     : in  std_logic_vector(7 downto 0);
      DataValidxSI  : in  std_logic;
      EndOfFramexSI : in  std_logic;
      CrcxDO        : out std_logic_vector(31 downto 0);
      CrcValidxSO   : out std_logic);
  end component;
  -- Types
  type state is (RST, IDLE, ETH_PRE, ETH_HEADER, IP_HEADER, UDP_HEADER, DATA, CRC, ETH_EXT);
  -- Signals
  -- Clock and reset signals
  signal Clock125xC          : std_logic;  -- 125MHz clock from the tranceiver
  signal ResetxRB            : std_logic;  -- active low reset signal
  signal StatexDP, StatexDN : state := RST;
  -- Transmit byte counter that is reset on each state transition. Max value is
  -- the max number of user data bytes allowed
  signal InStateCountxDP, InStateCountxDN : natural range 0 to MAX_UDP_BYTES;
  -- Counter to define the transmission period between consecutive frames
  signal SendPacketCountxDP, SendPacketCountxDN : unsigned(9 downto 0);
  -- Ethernet PHY TX-related signals
  signal TxEnxSP, TxEnxSN    : std_logic;  -- Transmit enable register
  signal TxErrxSP, TxErrxSN  : std_logic;  -- Transmit error register
  signal TxDataxD : std_logic_vector(7 downto 0);  -- Data to be transmitted
  -- Signals for the ethernet_crc block
  signal CrcSofxSP, CrcSofxSN : std_logic; -- (active high) indicates start of new frame
  signal CrcEofxSP, CrcEofxSN : std_logic;  -- indicates End Of Frame (active high)
  signal CrcDataValidxSP, CrcDataValidxSN : std_logic;  -- indicates valid data at the CRC generator input
  signal CrcByteInxD : std_logic_vector(7 downto 0);  -- byte for the crc calculation
  signal CrcValidxSP, CrcValidxSN : std_logic; -- (active high) indicates that crc result is valid
  signal CrcValuexDP, CrcValuexDN : std_logic_vector(31 downto 0);  -- current crc value from the crc generator
  --   CRC value to transmit: Latest CRC value with bytes reversed (LSB becomes MSB) and all bits inversed
  signal TxCrcValuexD : std_logic_vector(31 downto 0);
  -- Signals for the FIFO
  signal FifoRdEnxS    : std_logic := '0';  -- FIFO Read Enable signal
  signal FifoEmptyxS   : std_logic;     -- FIFO Empty signal
  signal FifoDataOutxD : std_logic_vector(7 downto 0);
  signal FifoRdCntUxD  : unsigned(11 downto 0);  -- FIFO Read data counter (unsigned)
  -- Signals related with the construction of the various fields of the Ethernet Frame
  signal EthernetHeaderxD    : std_logic_vector(111 downto 0);  -- the Ethernet header
  signal EthernetPreamblexD  : std_logic_vector(63 downto 0);  -- the Ethernet preamble
  signal IPHeaderxD          : std_logic_vector(159 downto 0);  -- the IP header
  signal IPLengthxD          : unsigned(15 downto 0); -- the IP Length in bytes
  signal IPHeadCheckSumxD    : unsigned(15 downto 0);
  signal IPHeadExtCheckSumxD : unsigned(16 downto 0);
  signal UDPHeaderxD         : std_logic_vector(63 downto 0);  -- the UDP header
  signal UDPLengthxD         : unsigned(15 downto 0);  -- the UDP datagram length in bytes
  signal UserDataLengthxDP, UserDataLengthxDN : unsigned(10 downto 0); -- Register that holds the user data length in bytes
  signal TxCarrierExtSymbolsxS : std_logic := '0';  -- '1' if we need to transmit carrier extension symbols, '0' otherwise
begin  -- behavioral
  -- Instances
  crcGenerator_1: crcGenerator
    port map (
      ClockxCI      => Clock125xC,
      ResetxRBI     => ResetxRB,
      NewFramexSI   => CrcSofxSP,
      DataInxDI     => CrcByteInxD,
      DataValidxSI  => CrcDataValidxSP,
      EndOfFramexSI => CrcEofxSP,
      CrcxDO        => CrcValuexDN,
      CrcValidxSO   => CrcValidxSN);
  -- Signal Assignments
  --SendPacketCountxDN <= SendPacketCountxDP + 1;
  BusyxSO <= '1' when StatexDP /= RST and StatexDP /= IDLE else '0';
  -- Clock and reset signals assignments
  Clock125xC <= GmiiGTxClkxCI;
  ResetxRB <= ResetxRBI;
  -- Ethernet PHY signals
  GmiiTxEnxSO <= TxEnxSP;
  GmiiTxDataxDO <= TxDataxD;
  GmiiTxErxSO <= TxErrxSP;
  -- FIFO Signals
  FifoRdEnxSO <= FifoRdEnxS;
  FifoDataOutxD <= FifoDataOutxDI;
  FifoEmptyxS <= FifoEmptyxSI;
  FifoRdCntUxD <= unsigned(FifoRdCntxDI);
  CrcByteInxD <= reverseByte(TxDataxD); -- crc input byte is the reversed transmitted byte in TxDataxD
  TxCrcValuexD <= not crcReversedBytes(CrcValuexDP);
  -- UDP Length: Length (in bytes) of the entire datagram: UDP header + UDP payload
  UDPLengthxD <= UDPHeaderxD'length + resize(UserDataLengthxDP, UDPLengthxD'length);
  -- IP Length: all data without the Ethernet header and without the Ethernet
  -- CRC. Thus we need the length of the UDP packet and the length of the IP
  -- header in bytes.
  IPLengthxD  <= UDPLengthxD + (IPHeaderxD'length/8);
  -- If user data are less than minimum size then transmission of Carrier
  -- Extension Symbols is needed. Set the flag.
  TxCarrierExtSymbolsxS <= '1' when to_integer(UserDataLengthxDP) < MIN_UDP_BYTES else '0';
  -- Headers. All transmitted MSByte first / LSBit first
  EthernetPreamblexD <= ETH_PREAMBLE;
  EthernetHeaderxD <= DEST_MAC_ADDRESS & SRC_MAC_ADDRESS & ETH_TYPE;
  IPHeaderxD <= IP_VERSION & IP_HDR_LENGTH & IP_TOS & std_logic_vector(IPLengthxD) & IP_MSG_ID & IP_FLAGS & IP_TTL & IP_PROTOCOL & std_logic_vector(IPHeadCheckSumxD) & SRC_IP_ADDRESS & DEST_IP_ADDRESS;
  UDPHeaderxD <= SRC_UDP_PORT & DEST_UDP_PORT & std_logic_vector(UDPLengthxD) & UDP_CHECKSUM;
  -- purpose: Compute the IP Header Checksum
  -- type   : combinational
  -- inputs : IPHeaderxD
  -- outputs: IPHeadCheckSumxD
  ipheader_checksum: process (IPHeaderxD)
  begin  -- process ipheader_checksum
    IPHeadExtCheckSumxD <= (others => '0');  -- initialize
    for i in 0 to IPHeaderxD'length/8-1 loop
      if i /= 10 and i /= 11 then       -- ignore the checksum bytes
        IPHeadExtCheckSumxD <= IPHeadExtCheckSumxD + unsigned(IPHeaderxD((IPHeaderxD'length-1)-8*i downto (IPHeaderxD'length-8)-8*i));
      end if;
      if IPHeadExtCheckSumxD(IPHeadExtCheckSumxD'high) = '1' then
        IPHeadExtCheckSumxD <= '0' & IPHeadExtCheckSumxD(IPHeadCheckSumxD'high downto 0) + to_unsigned(1, IPHeadExtCheckSumxD'length);
      end if;
    end loop;  -- i
    IPHeadCheckSumxD <= not IPHeadExtCheckSumxD((IPHeadcheckSumxD'length-1) downto 0);
  end process ipheader_checksum;
  -- Processes
  -- State machine
  fsm_memless : process (CrcDataValidxSP, EthernetHeaderxD, EthernetPreamblexD,
                         FifoDataOutxD, FifoRdCntUxD, IPHeaderxD,
                         InStateCountxDP, ResetxRB, SendPacketCountxDP,
                         StatexDP, TxCarrierExtSymbolsxS, TxCrcValuexD,
                         TxEnxSP, TxErrxSP, UDPHeaderxD, UserDataLengthxDP)
  begin  -- process fsm_memless
    -- Defaults
    StatexDN            <=      StatexDP;
    TxEnxSN             <=      TxEnxSP;
    TxErrxSN            <=      TxErrxSP;
    TxDataxD            <=      (others => '0');
    UserDataLengthxDN   <=      UserDataLengthxDP;
    FifoRdEnxS          <=      '0';
    CrcSofxSN           <=      '0';
    CrcEofxSN           <=      '0';
    CrcDataValidxSN     <=      CrcDataValidxSP;
    if InStateCountxDP < MAX_UDP_BYTES then
      InStateCountxDN <= InStateCountxDP + 1;
    else
      InStateCountxDN <= 0;
    end if;
    -- States
    case StatexDP is
      -- Come and remain here as long as the block is in reset
      when RST =>
        if ResetxRB = '1' then
          StatexDN <= IDLE;
        end if;
      -- Wait until time for next Ethernet frame transmission has come
      when IDLE =>
        if SendPacketCountxDP = 0 and FifoRdCntUxD /= 0 then  -- and FifoRdCntUxD >= 1472
          TxEnxSN         <= '1';
          InStateCountxDN <= 0;  -- reset counter
          StatexDN        <= ETH_PRE;   -- Go to transmit the Ethernet preamble
        end if;
      -- Transmit the Ethernet Preamble (8 byte / 64 bit)
      when ETH_PRE =>
        TxDataxD <= EthernetPreamblexD((EthernetPreamblexD'length-1)-InStateCountxDP*8 downto (EthernetPreamblexD'length-8)-InStateCountxDP*8);
        if InStateCountxDP = 7 then     -- End of ethernet preamble transmission
          CrcSofxSN       <= '1';       -- a new frame now starts for which CRC is to be computed
          CrcDataValidxSN <= '1';       -- From now on Tx data are valid for CRC
          StatexDN        <= ETH_HEADER; -- Go to transmit the Ethernet header
        end if;
      -- Transmit the Ethernet Header (14 byte / 112 bit)
      when ETH_HEADER =>
        TxDataxD <= EthernetHeaderxD((EthernetHeaderxD'length-1)-InStateCountxDP*8 downto (EthernetHeaderxD'length-8)-InStateCountxDP*8);
        if InStateCountxDP = 13 then     -- End of Ethernet header transmission
          if FifoRdCntUxD > MAX_UDP_BYTES then
            UserDataLengthxDN <= to_unsigned(MAX_UDP_BYTES, UserDataLengthxDN'length);
          else
            UserDataLengthxDN <= resize(FifoRdCntUxD, UserDataLengthxDN'length);
          end if;
          StatexDN        <= IP_HEADER;  -- go to transmit the IP Header
        end if;
      -- Transmit the IP Header (20 byte / 160 bit)
      when IP_HEADER =>
        TxDataxD <= IPHeaderxD((IPHeaderxD'length-1)-InStateCountxDP*8 downto (IPHeaderxD'length-8)-InStateCountxDP*8);
        if InStateCountxDP = 19 then    -- End of IP header transmission
          StatexDN        <= UDP_HEADER;  -- Go to transmit the UDP Header
        end if;
      -- Transmit the UDP Header (8 byte / 64 bit)
      when UDP_HEADER =>
        TxDataxD <= UDPHeaderxD((UDPHeaderxD'length-1)-InStateCountxDP*8 downto (UDPHeaderxD'length-8)-InStateCountxDP*8);
        if InStateCountxDP = 7 then     -- End of UDP header transmission
          FifoRdEnxS      <= '1';
          StatexDN        <= DATA;      -- Go to transmit the user data
        end if;
      -- Transmit the User Data
      when DATA =>
        TxDataxD <= FifoDataOutxD;
        -- Assert the End Of Frame signal
        if InStateCountxDP = to_integer(UserDataLengthxDP) - 2 then
          CrcEofxSN <= '1';
        end if;
        if InStateCountxDP = to_integer(UserDataLengthxDP) - 1 then
          CrcDataValidxSN <= '0'; -- Data are not valid any more for CRC
          StatexDN        <= CRC;             -- Go to transmit the calculated CRC
        else
          FifoRdEnxS <= '1';
        end if;
      -- Transmit the 32-bit CRC data
      when CRC =>
        case InStateCountxDP is
          when 0 =>
            TxDataxD <= TxCrcValuexD((TxCrcValuexD'length-1) downto (TxCrcValuexD'length-8));
          when 1 =>
            TxDataxD <= TxCrcValuexD((TxCrcValuexD'length-9) downto (TxCrcValuexD'length-16));
          when 2 =>
            TxDataxD <= TxCrcValuexD((TxCrcValuexD'length-17) downto (TxCrcValuexD'length-24));
          when 3 =>
            TxDataxD <= TxCrcValuexD((TxCrcValuexD'length-25) downto (TxCrcValuexD'length-32));
            TxEnxSN <= '0'; -- de-assert the TX Enable signal
            -- If the TxCarrierExtSymbolsxS flag is asserted, go to transmit
            -- the carrier extension symbols. Otherwise the frame transmission
            -- is over. Go to IDLE.
            if TxCarrierExtSymbolsxS = '1' then
              TxErrxSN <= '1';          -- Assert the TX_ER on next cycle
              StatexDN <= ETH_EXT;
            else
              SendPacketCountxDN <= (others => '0');
              StatexDN <= IDLE;
            end if;
          when others => null;
        end case; -- InStateCountxDP
      -- Transmit Carrier Extnesion Symbols until min frame length is reached
      when ETH_EXT =>
        -- Keep the TX_ER flag asserted until the min frame length is reached
        if InStateCountxDP >= (MIN_UDP_BYTES - to_integer(UserDataLengthxDP) - 1) then
          TxErrxSN <= '0';
          StatexDN <= IDLE;      -- Frame transmission is over
        end if;
    end case; -- StatexDP
  end process fsm_memless;
  -- Registers
  registers_memzing : process (Clock125xC, ResetxRB)
   begin  -- process registers_memzing
     if ResetxRB = '0' then              -- asynchronous reset (active low)
       StatexDP                 <=      RST;
       TxEnxSP                  <=      '0';
       TxErrxSP                 <=      '0';
       UserDataLengthxDP        <=      (others => '0');
       InStateCountxDP          <=      0;
       SendPacketCountxDP       <=      (others => '0');
       CrcSofxSP                <=      '0';
       CrcEofxSP                <=      '0';
       CrcDataValidxSP          <=      '0';
       CrcValuexDP              <=      (others => '0');
       CrcValidxSP              <=      '0';
     elsif Clock125xC'event and Clock125xC = '1' then  -- rising clock edge
       StatexDP                 <=      StatexDN;
       TxEnxSP                  <=      TxEnxSN;
       TxErrxSP                 <=      TxErrxSN;
       UserDataLengthxDP        <=      UserDataLengthxDN;
       InStateCountxDP          <=      InStateCountxDN;
       SendPacketCountxDP       <=      SendPacketCountxDN;
       CrcSofxSP                <=      CrcSofxSN;
       CrcEofxSP                <=      CrcEofxSN;
       CrcDataValidxSP          <=      CrcDataValidxSN;
       CrcValuexDP              <=      CrcValuexDN;
       CrcValidxSP              <=      CrcValidxSN;
     end if;
   end process registers_memzing;
end behavioral;
 The GMII interface has the GmiiGTxClkxCI, GmiiTxEnxSO, GmiiTxErxSO and GmiiTxDataxDO signals. And so GmiiGTxClkxCI is the clock reference of the other three. So what I am thinking is that since the block is clocked by the Clk125MxC signal whereas the clock that the 88E1111 PHY chip receives is the GmiiGTxClkxCO from the ODDR2, is there any problem in that? I mean most probably what I'm saying is stupid, but I'm really confused.
Anyway, thank you for the help!
Nikos
Teacher eteam00
Try the following highlighted changes:
ethPLL_1: ethPLL
  port map (
-- Place the following after the 'begin' keyword
 inv_Clk125MxC <= NOT Clk125MxC;
--        Spartan-3E/3A/6
 ODDR2_inst : ODDR2
 generic map(
 port map (
    C1 => inv_Clk125MxC, -- 1-bit clock input
If this does not clear up the error message, then comment out the ODDR2 primitive and recompile.  If the error message persists, the coding error is somewhere else in your design.
Sorry, you have already hijacked this existing thread with a (barely) related topic.  This is considered rude.  Muddling a single thread with more than one discussion topic isn't just rude, it is also confusing to readers and participants.  If you have a second discussion topic, it's time to start a separate thread.
-- Bob Elkind
SIGNATURE:
Summary:
I have a note not regarding the subject, but the ddr2 instantiation.
I am referring to the inverted clock, which is required for DDR2 operation.
I also tried this, that way with a Spartan 6 to route an internal clock from inside the FPGA to an external chip. However the synthesis would not let me use an inverted clock from just an inverter for the second input c1.  I had to create another clock coming from the DCM with 180 Phase delay, to get it routed.
 (14.2)
Teacher eteam00
In Spartan-6, using a clock buffered with a BUFG, a single clock polarity is sufficient.  The DDR logic in the IOB includes a selectable clock polarity inverter which is compatible with BUFG-driven clocks.
-- Bob Elkind
SIGNATURE:
Summary:
Newbie vorlk45
Hi bob,
My experiments show that your code gives an inverted clock output. Since d0 is output on the rising edge of clock c0, d0 should be '1' and conversly d1 '0'... or am i completely crazy???
This gave the proper polarity clock output for me:
D0 => '1', -- 1-bit data input (associated with C0)
D1 => '0', -- 1-bit data input (associated with C1)
Cheers!
che
Visitor mona_liza
I have a clock wizard in my vhdl code. I want to map it's input and output clock to I/O pins.
As you said I read this document: https://www.xilinx.com/support/documentation/sw_manuals/xilinx13_4/spartan6_hdl.pdf
.I also used the mentioned template in the language template. But I still get this message error in synthesize step :"ERROR:Xst:2035 - Port <CLOCK_24> has illegal connections. This port is connected to an input buffer and other components"
What is the problem?! What I have to do?
This is some part of my code:
ODDR2_inst : ODDR2
   generic map(
      INIT => '0',
      SRTYPE => "SYNC")
   port map (
      Q => frq_out_delayed,
      C0 =>  CLOCK_96,
      C1 => not CLOCK_96,
      CE => '1',
      D0 => '0',
      D1 => '1',
      R => '0',
      S => '0'
 ODDR2_inst2 : ODDR2
   generic map(
      INIT => '0',
      SRTYPE => "SYNC")
	port map (
      Q => frq_out,
      C0 => clk_6,
      C1 => not clk_6,
      CE => '1',
      D0 => '0',
      D1 => '1',
      R => '0',
      S => '0'
	CLOCK_PLL_4x : CLOCK port map (
		CLK_IN1 => CLOCK_24,
		CLK_OUT1 => CLOCK_96,
		PSCLK => SPI_CLK,
		PSEN => not SPI_EN,
		PSINCDEC => SPI_DATA,
		PSDONE => PROG_DONE,
		RESET  => not CLEAR,
		LOCKED => open
