Visitor kanwal_
how to instantiate ODDR block?
hi
please tell me how to instantiate ODDR block to remov DCM clocking error 1203 in spartan 6......plz urgently give me the ans?
Re: how to instantiate ODDR block?
Teacher eteam00
Using ODDR for Clock forwarding
If you reference a specific error message code, you should include the text of the error message in your post.  I am not familiar with "DCM clocking error 1203".
If the question is:
How do I forward an internal global clock to an output pin?
the answer is an approach which is
  • well documented
  • applies (generally) to all FPGA families
  • called 'clock forwarding'
Specifically, try the following:
  • Open ISE
  • Click on the 'light bulb' icon to bring up the Language Templates window
  • Follow Verilog (or VHDL)>Synthesis Constructs>Coding Examples>Misc>Output Clock Forwarding Using DDR
  • Read the Info section, as well as the family-specific sections
For Verilog and Spartan-6, you will find the following example:
   // Clock forwarding circuit using the double data-rate register
   //        Spartan-3E/3A/6
   // Xilinx HDL Language Template, version 13.4
   ODDR2 #(
      .DDR_ALIGNMENT("NONE"), // Sets output alignment to "NONE", "C0" or "C1"
      .INIT(1'b0),    // Sets initial state of the Q output to 1'b0 or 1'b1
      .SRTYPE("SYNC") // Specifies "SYNC" or "ASYNC" set/reset
   ) clock_forward_inst (
      .Q(<output_clock>),     // 1-bit DDR output data
      .C0(<internal_clock>),  // 1-bit clock input
      .C1(~<internal_clock>), // 1-bit clock input
      .CE(<stop_clock>),      // 1-bit clock enable input
      .D0(1'b0), // 1-bit data input (associated with C0)
      .D1(1'b1), // 1-bit data input (associated with C1)
      .R(<hold_clock_low>),   // 1-bit reset input
      .S(<hold_clock_high>)   // 1-bit set input
   // End of clock_forward_inst instantiation
The following example showing clock forwarding to an output pin is edited from UG382, Figure 3-13:
-- Bob Elkind
SIGNATURE:
Summary:
Visitor kanwal_
Re: Using ODDR for Clock forwarding
hi, thanks for your quick response ...,,,
//actually i made a following verilog program
module (clk_in,clk_out1,clk_out2)
input clk_in; output clk_out1,clk_out2;
// instantiate dcm
mydcm 1 (
  .CLK_IN1(clk_in1),
  .CLK_OUT1(clk_out1), // same as input clk
  .CLK_OUT2(clk_out2)  // clk2x
endmodule
during mapping i get following error :
"ERROR:Place:1136 - This design contains a global buffer instance,
   <uut/clkout1_buf>, driving the net, <CLK_OUT1_OBUF>, that is driving the
   following (first 30) non-clock source pins.
   < PIN: CLK_OUT1.O; >"
to solve this problem i add oddr2 in my prog but still get the same error please help me to solve this problem
i shall be very thankful to you.
Visitor aliaarshad
"clock_forward_inst" failed to join the "OLOGIC2" component as required.
hi,
i tried to instantiate oddr2 in my verilog program bt during mapping it gives the following error
Pack:2531 - The dual data rate register "clock_forward_inst" failed to
join the "OLOGIC2" component as required. The output signal for register
symbol clock_forward_inst requires general routing to fabric, but the
register can only be routed to ILOGIC, IODELAY, and IOB.
ERROR:Pack:2531 - The dual data rate register "clock_forward_inst" failed to
join the "OLOGIC2" component.
how to overcome this problem?
i will be very thankful for your response.
thanks
aliya
Teacher eteam00
please start a new thread
Aliya, please start a new thread to discuss your separate problem.  This thread is for discussing kanwal's design.
-- Bob Elkind
SIGNATURE:
Summary:
Teacher eteam00
Kanwal,
You have signals connected improperly, including a clock signal driving non-clock pins.  If you cannot fix this on your own, then please post your source code which includes all clock signal connections and references.
A BUFG output cannot drive an OBUF input directly.
-- Bob Elkind
SIGNATURE:
Summary:
Re: "clock_forward_inst" failed to join the "OLOGIC2" component as required.
The ODDR in the OLOGIC component has very limited connectivity. Usually it should be driving a single output buffer. The error message indicates your ODDR is driving fabric logic which cannot be supported.
Observer suresh007
hi sir,
its fine with spartan6
can you please help me out in KINTEX 7BOARD
CLOCKING_WIZARD--------->ODDR------>OBUF-------->GPIOPIN(Y23)
idea is to check the clock perfomance on the pin
please do correct me if Im wrong
Any help will be highly appreciable !!!!!!!!!
Thanks in advance
Suresh
Newbie jagsshete
ERROR:Pack:2531 - The dual data rate register "DCM1/clock_3" failed to join the
"OLOGIC2" component as required. The output signal for register symbol
DCM1/clock_3 requires general routing to fabric, but the register can only be
ERROR:Pack:2530 - The dual data rate register "DCM1/clock_1" failed to join an
OLOGIC component as required.
plese help me ....
DCM for spartan 6 lx 45 device is but it gives erroe 1130 but it eleminated by using ODDR2. DCM output given to ODDR2 but it gives above error.
suggest me solution..
Newbie jagsshete
plese help me ....
DCM for spartan 6 lx 45 device is selected  but it gives error 1130 but it eleminated by using ODDR2. DCM output given to ODDR2 but it gives above error.
Visitor mkjaswal
hey anyone found any solution to this PLEASE!!!
MKJ
Community Manager
Community Manager
Hi @mkjaswal,
In our Help Page there is a tip
Tip: If the message is older than 6-12 months, please post a new message rather than adding to the existing thread. Your inquiry will have a better chance of being picked up by an expert if it is a new topic.
https://forums.xilinx.com/t5/help/faqpage/faq-category-id/posting#posting
This question is 3 years old with 11 replies so you will probably get more traction if you create a new post with your question.
Visitor mkjaswal
@sandrao   ok i will do it
MKJ
