Visitor dohoonh
inverted PWM signal with AXI timer
Hi, I am developing PWM control system with SP605 board.
Up to this point, I can use the AXI timer to create a PWM signal.
But I want to invert the PWM signal.
Instead of simply putting the inverter, does the AXI timer itself have that capability?
Re: inverted PWM signal with AXI timer
Hi @dohoonh,
It is not possible using the AXI Timer. AXI Timer don't have that capability.
Please check the below statement
Here the timer 0 used to set the period of the PWM signal and Timer 1 sets the on time of the signal.
there is no way in the AXI timer to invert these signals.
Best Regards,
Srikanth
Hi @dohoonh,
Best Regards,
Srikanth
Visitor dohoonh
I am really grateful for your kind reply.
I will use inverter to solve.
