2016.2 Synthesis error- regarding module contain entity which was created in system generator
I got the following error when I execute Synthesis
[Synth 8-3493] module 'decore_bd' declared at 'C:/project/syn/syn.runs/synth_1/.Xil/Vivado-10060-proj/realtime/decore_bd_stub.vhdl:5' does not have matching formal port for component port 'tl_out' ["C:/project/ip_repo/bd/decore_bd/hdl/decore_bd_wrapper.vhd":127]
decore_bd_wrapper is a wrapper which contain module which was created in system generator
Hi @sarit8
Looks like port declared in the module 'decore_bd' and instantiated as the component declaration in the wrapper file are different.
Make sure that the component file and the top level file have the same ports instantiated and used.
From sources view you can open design_1_wrapper.vhd and design_1 and see if there is a port mismatch between them. if it is the case, regenerate the wrapper by removing the old one from project, then create a new HDL wrapper by clicking the block design in the sources view.
Hope the shared information helps.
Rohit
Rohit
Hi @sarit8,
Check if port is declared in module instantiation for 'tl_out' in decore_bd_stub.vhdl.
Prathik
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
Hi @sarit8
Did the given suggestions helped? Let me know if you face any issues.
Rohit
Rohit
