JR_97
4-bit ALU having syntax and other errors, advice needed.
I currently have a vivando project that is designed to run a 4-bit arithmetic logic unit that runs on the device Artix-7 FPGA (XC7A100TCSG324-1) with a 1-bit adder and a 1-bit alu. I am very new to vhdl and am having trouble figuring out how to set up the architectual behavior and port map for the 4-bit alu.
Does anyone know what I need change to eliminate my errors? Any help is appreciated.
4-bit alu:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY Alu4 IS
GENERIC( CONSTANT N: INTEGER := 4; -- 4 bits ALU
CONSTANT Z: STD_LOGIC_VECTOR(3 DOWNTO 1) := "000" -- 3 Zeros
PORT(
a, b: IN STD_LOGIC_VECTOR(N-1 DOWNTO 0);
control: IN STD_LOGIC_VECTOR(1 DOWNTO 0);
overflow: OUT STD_LOGIC;
zero: OUT STD_LOGIC;
cOut: OUT STD_LOGIC;
result: OUT STD_LOGIC_VECTOR(N-1 DOWNTO 0)
END Alu4;
ARCHITECTURE behavioral OF Alu4 IS
COMPONENT Alu1
PORT(
a: IN STD_LOGIC;
b: IN STD_LOGIC;
cIn: IN STD_LOGIC;
END COMPONENT;
SIGNAL carry_sig: STD_LOGIC_VECTOR(N DOWNTO 0); -- carry_sig(N) = MSB cOut
SIGNAL result_sig: STD_LOGIC_VECTOR(N-1 DOWNTO 0);
BEGIN ## this is where the errors are all located.
uut: Alu1 PORT MAP(a => a, b => b, cOut_sig, result_sig);
process (a, b, control)
BEGIN
case control is
WHEN "000" =>
cOut = a AND b,
WHEN "001" =>
cOut = a OR b,
WHEN "010" =>
cOut = a + b,
WHEN "011" =>
cOut = a - b,
WHEN "100" =>
cOut = NOT a,
WHEN "101" =>
cOut = a XOR b,
WHEN "110" =>
cOut = a + 1,
WHEN "111" =>
cOut = a - 1,
WHEN others =>
NULL;
END case;
END process;
END behavioral;
Also here is the 1-bit alu code:
LIBRARY IEEE;
ENTITY Alu1 IS
PORT(
a: IN STD_LOGIC; -- Input SW[2]
b: IN STD_LOGIC; -- Input SW[1]
cIn: IN STD_LOGIC; -- Input SW[0]
control: IN STD_LOGIC_VECTOR(1 DOWNTO 0); -- Input SW[15..14]: control[1..0]
cOut: OUT STD_LOGIC; -- Output LED[1]
result: OUT STD_LOGIC -- Output LED[0]
END Alu1;
ARCHITECTURE behavioral OF Alu1 IS
COMPONENT Adder1
PORT (
a, b, cIn : IN std_logic;
cOut, sum : OUT std_logic);
END COMPONENT;
SIGNAL a_sig, b_sig: STD_LOGIC;
SIGNAL sum_sig, cOut_sig: STD_LOGIC;
SIGNAL result_sig: STD_LOGIC;
BEGIN
a_sig <= a;
b_sig <= NOT b WHEN control = "11" ELSE
b;
U1:Adder1 PORT MAP(a_sig, b_sig, cIn, cOut_sig, sum_sig);
WITH control SELECT
result_sig <=
a AND b WHEN "00",
a OR b WHEN "01",
sum_sig WHEN "10",
sum_sig WHEN "11",
sum_sig WHEN Others;
result <= result_sig;
cOut <= '0' WHEN control = "00" OR control = "01" ELSE
cOut_sig;
END behavioral;
and finally the 1-bit adder code:
LIBRARY IEEE;
ENTITY Adder1 IS
PORT (
END Adder1;
ARCHITECTURE behavioral OF Adder1 IS
BEGIN
cOut <= (a and b) or ((a xor b) and cIn);
sum <= (a xor b) xor cIn;
END behavioral;
This alu is designed to run with this simulation file:
LIBRARY IEEE;
ENTITY Alu4_tb IS
END Alu4_tb;
ARCHITECTURE simulate OF Alu4_tb IS
COMPONENT Alu4
PORT( a, b: IN STD_LOGIC_VECTOR(3 DOWNTO 0);
result: OUT STD_LOGIC_VECTOR(3 DOWNTO 0)
END COMPONENT;
SIGNAL a, b: STD_LOGIC_VECTOR(3 DOWNTO 0);
SIGNAL control: STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL overflow: STD_LOGIC;
SIGNAL zero: STD_LOGIC;
SIGNAL cOut: STD_LOGIC;
SIGNAL result: STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
uut: Alu4 PORT MAP(
a, b, control,
overflow, zero, cOut, result);
stimulus: PROCESS
BEGIN
-- test bench stimulus code
-- "0000" AND "0000": overflow<='0', zero<='1', cOut<='0', result<="0000"
a <= "0000"; b <= "0000"; control <= "00";
WAIT FOR 40 ns;
-- "0111" AND "0001": overflow<='0', zero<='0', cOut<='0', result<="0001"
a <= "0111"; b <= "0001"; control <= "00";
WAIT FOR 40 ns;
-- "0111" AND "1111": overflow<='0', zero<='0', cOut<='0', result<="0111"
a <= "0111"; b <= "1111"; control <= "00";
WAIT FOR 40 ns;
-- "1111" AND "0111": overflow<='0', zero<='0', cOut<='0', result<="0111"
a <= "1111"; b <= "0111"; control <= "00";
WAIT FOR 40 ns;
-- "1000" AND "0001": overflow<='0', zero<='1', cOut<='0', result<="0000"
a <= "1000"; b <= "0001"; control <= "00";
WAIT FOR 40 ns;
-- "1000" AND "1111": overflow<='0', zero<='0', cOut<='0', result<="1000"
a <= "1000"; b <= "1111"; control <= "00";
WAIT FOR 40 ns;
-- "0000" OR "0000": overflow<='0', zero<='1', cOut<='0', result<="0000"
a <= "0000"; b <= "0000"; control <= "01";
WAIT FOR 40 ns;
-- "0111" OR "0001": overflow<='0', zero<='0', cOut<='0', result<="0111"
a <= "0111"; b <= "0001"; control <= "01";
WAIT FOR 40 ns;
-- "0111" OR "1111": overflow<='0', zero<='0', cOut<='0', result<="1111"
a <= "0111"; b <= "1111"; control <= "01";
WAIT FOR 40 ns;
-- "1111" OR "0111": overflow<='0', zero<='0', cOut<='0', result<="1111"
a <= "1111"; b <= "0111"; control <= "01";
WAIT FOR 40 ns;
CMPS375 (Lab 4) Page 5 / 10 Dr. Kuo-pao Yang
-- "1000" OR "0001": overflow<='0', zero<='0', cOut<='0', result<="1001"
a <= "1000"; b <= "0001"; control <= "01";
WAIT FOR 40 ns;
-- "1000" OR "1111": overflow<='0', zero<='0', cOut<='0', result<="1111"
a <= "1000"; b <= "1111"; control <= "01";
WAIT FOR 40 ns;
-- "0000" ADD "0000": overflow<='0', zero<='1', cOut<='0', result<="0000"
a <= "0000"; b <= "0000"; control <= "10";
WAIT FOR 40 ns;
-- "0111" ADD "0001": overflow<='1', zero<='0', cOut<='0', result<="1000"
a <= "0111"; b <= "0001"; control <= "10";
WAIT FOR 40 ns;
-- "0111" ADD "1111": overflow<='0', zero<='0', cOut<='1', result<="0110"
a <= "0111"; b <= "1111"; control <= "10";
WAIT FOR 40 ns;
-- "1111" ADD "0111": overflow<='0', zero<='0', cOut<='1', result<="0110"
a <= "1111"; b <= "0111"; control <= "10";
WAIT FOR 40 ns;
-- "1000" ADD "0001": overflow<='0', zero<='0', cOut<='0', result<="1001"
a <= "1000"; b <= "0001"; control <= "10";
WAIT FOR 40 ns;
-- "1000" ADD "1111": overflow<='1', zero<='0', cOut<='1', result<="0111"
a <= "1000"; b <= "1111"; control <= "10";
WAIT FOR 40 ns;
-- "0000" SUB "0000": overflow<='0', zero<='1', cOut<='1', result<="0000"
a <= "0000"; b <= "0000"; control <= "11";
WAIT FOR 40 ns;
-- "0111" SUB "0001": overflow<='0', zero<='0', cOut<='1', result<="0110"
a <= "0111"; b <= "0001"; control <= "11";
WAIT FOR 40 ns;
-- "0111" SUB "1111": overflow<='1', zero<='0', cOut<='0', result<="1000"
a <= "0111"; b <= "1111"; control <= "11";
WAIT FOR 40 ns;
-- "1111" SUB "0111": overflow<='0', zero<='0', cOut<='1', result<="1000"
a <= "1111"; b <= "0111"; control <= "11";
WAIT FOR 40 ns;
-- "1000" SUB "0001": overflow<='1', zero<='0', cOut<='1', result<="0111"
a <= "1000"; b <= "0001"; control <= "11";
WAIT FOR 40 ns;
-- "1000" SUB "1111": overflow<='0', zero<='0', cOut<='0', result<="1001"
a <= "1000"; b <= "1111"; control <= "11";
WAIT FOR 40 ns;
WAIT;
END PROCESS;
END simulate;
richardhead
You have a couple of problems in this code:
1.
You have positional association after named association. This is illegal. Positional must be used before named association. I recommended using named association for ALL mappings in a port map. You have also not mapped any output signals from the component, and signals you have mapped do not correspond to the correct ports. Hence why named assiciation is ALWAYS recommended.
2. You have a lot of arithmetic functions on std_logic. There are no functions defined for "+" "-" etc. on a single std_logic. I recommend reading up on the VHDL package numeric_std, and how to use it. If you can use VHDL 2008, you can also consider numeric_std_unsigned. std_logic_unsigned should not be used as it is not a VHDL standard.
bruce_karaffa
 In addition @richardhead's excellent advice, I would also like to point out that I don't see any clocked processes in your code.  You are unlikely to make this work in an FPGA with completely asynchronous coding.  Also, if you tell us what errors you are seeing and exactly where in the code they are, we could offer more help.
maps-mpls
Mentor
Mentor
Also, when pasting code, use the </> symbol, or click on the HTML graphic, and insert your code between a <pre> </pre>.  It would allow more people to quickly ascertain what is going on in your code.
*** Destination: Rapid design and development cycles *** Unappreciated answers get deleted, unappreciative OPs get put on ignored list ***
