Newbie alexmakarov
7-serives issue. FD and FD_1 are optimised into IDDR
I am trying to implement Xapp1015 on a 7-series device.
I am encountering  a problem when FD and FD_1 are optimised into IDDR by Vivado.
My code explicitly instantiates FDs and FD_1s  which then location constrained in the XDC as follows:
QF0 : FD_1
port map (
Q => QF(0), -- Data output
C => CLK270(0), -- Clock input
D => asi_rx -- Data input
QF1 : FD_1
port map (
Q => QF(1), -- Data output
C => CLK270(1), -- Clock input
QF2 : FD_1
port map (
Q => QF(2), -- Data output
C => CLK270(2), -- Clock input
QF3 : FD_1
port map (
Q => QF(3), -- Data output
C => CLK270(3), -- Clock input
QR0 : FD
port map (
Q => QR(0), -- Data output
QR1 : FD
port map (
Q => QR(1), -- Data output
QR2 : FD
port map (
Q => QR(2), -- Data output
QR3 : FD
port map (
Q => QR(3), -- Data output
My XDC constraints:
set_property LOC SLICE_X0Y73 [get_cells {*/u_asi_lvds_rx/dru_8phase/QR0}];
set_property LOC SLICE_X0Y74 [get_cells {*/u_asi_lvds_rx/dru_8phase/QF0}];
set_property LOC SLICE_X1Y73 [get_cells {*/u_asi_lvds_rx/dru_8phase/QR1}];
set_property LOC SLICE_X1Y74 [get_cells {*/u_asi_lvds_rx/dru_8phase/QF1}];
set_property LOC SLICE_X2Y73 [get_cells {*/u_asi_lvds_rx/dru_8phase/QR2}];
set_property LOC SLICE_X2Y74 [get_cells {*/u_asi_lvds_rx/dru_8phase/QF2}];
set_property LOC SLICE_X3Y73 [get_cells {*/u_asi_lvds_rx/dru_8phase/QR3}];
set_property LOC SLICE_X3Y74 [get_cells {*/u_asi_lvds_rx/dru_8phase/QF3}];
The result is that QR0 and QR1 are optimised into IDDR and are not placed into X0Y73 and X0Y77 as specified in the XDC.
 A solution was proposed here for ISE and a Spartan Device:
https://forums.xilinx.com/t5/Spartan-Family-FPGAs/Spartan-6-issue-FD-FD-1-optimized-to-an-IDDR2/td-p/467374
However it does not seem to work in Vivado and Virtex-7.    How do I prevent a FD and FD_1 being optimised into IDDR?
Please advise.
Historian
Historian
Re: 7-serives issue. FD and FD_1 are optimised into IDDR
You could try putting a DONT_TOUCH property on the flip-flops, but I am not sure this is the best approach...
Trying to oversample a signal by using multiple flip-flops with different clock phases is not very precise - the delay of routing from the IBUF to the different flip-flops is hard to control (as you are seeing).
A better solution is to oversample it with only one sampling device - the most obvious choice is the ISERDES. The ISERDES already has an "OVERSAMPLE" mode, which allows you to get 4 samples per "clock"as long as you have both a 0degree and 90degree version of the same clock (through the same type of clock buffer). Alternatively, (unless the frequency is too high), you can generate a 1x clock and a 4x clock, and use the ISERDES in 8:1 deserialization with DDR mode - this will generate 8 evenly spaced samples of your incoming signal in one low speed clock.
Avrum
Historian
Historian
Avrum
Hi Alex,
I am able to make things work for Kintex-7 (which should be similar to Virtex-7) by doing the following:
As suggest in the referenced Spartan-6 post, your VHDL should have something like the following:
    signal QF, QR : std_logic_vector(3 downto 0);
    ATTRIBUTE IOB : string;
    ATTRIBUTE IOB of QF, QR : signal is "FALSE";
Next, your XDC LOC constraints should be similar to the following:
set_property LOC SLICE_X0Y73 [get_cells {*/u_asi_lvds_rx/dru_8phase/QR_reg[0]}];
set_property LOC SLICE_X0Y74 [get_cells {*/u_asi_lvds_rx/dru_8phase/QF_reg[0]}];
...note use of QR_reg[0] and QF_reg[0] instead of QR0 and QF0 (that you used).
Please consider Avrum's suggestions about ISERDES.
Mark
