msaideroglu
[8-439] submodule not found error
I am trying to synthesize a top module systemverilog design. It has various submodules. all submodules are synthesized correctly. Everything seems fine but when I try to synthesize top module, I am getting "submodule "xyz" not found" error. Any idea please?
surajc
Hi @msaideroglu
Can you show us the hierarchy of your design, from the hierarchy window?
msaideroglu
Here it is: also there is a conditional expression could not be resolved as constant error although the expression is purely logical:
like (genvar i=0;i<3;i=i+1)
Screenshot from 2020-09-04 11-26-11.pngScreenshot from 2020-09-04 11-26-32.png
msaideroglu
All submodules can be generated seperately. Those submodules are grayed out at bottom. Is there any meaning?
surajc
Hi @msaideroglu
Do you see any missing sources in the project when you select this button in GUI?
The greying out tells us that these files are a part of conditional if generate code and they are not instantiated as per your conditional if generate code
For example, see the down-counter file in the below snapshot
msaideroglu
There is no missing file. In this project, when I set top all modules seperately, it can be synthesized.
anusheel
@msaideroglu
Can you please share the snippet of the generate block, if possible please share a testcase?
Anusheel
