A NOT function vs register assignment
I'm using ISE 14.7 in order to do a design for Spartan 6. I have the following VHDL code snippet, a and b are std_logic signals and their values can only be either '1' or '0':
if (a /= b) then
  a <=b;
end if;
if (a /= b) then
  a <= not a;
end if;
I have to do this kind of assignment many times in different places of my design. Which one is more optimal for XST? The first one I suppose that is only routing a signal. What about the second? I didn't find anything in XST User guide...
Re: A NOT function vs register assignment
Hi fdomingues@ulmaembedded.com,
I would expect the same results, using a LUT2 in both cases.
Florent
Florent
Florent
Florent
As @florentw has said, they both simplify down to the same logic equation to use for a lookup table - and since Xilinx FPGAs are all based on lookup tables they will therefore produce identical hardware in every way.
I suppose that on a CPLD (not based on lookup tables - instead they're programmable interconnects between fixed gates) you could actually produce different hardware for each option. However, since the logic tools will first simplify the logic equation and then implement that, it's very likely that you could only achieve a different behaviour with a great deal of effort.
