araongao2015
Add .dcp or add .xci, which one is better?
  I use Vivado "Manage IP" to create an IP project and generate all target files of each IP here. Then I add IP in my Vivado project, I find I can add .xci or .dcp directly. which one is practicable?
Best Regards
araongao2015
Hi @ashishd:
  Thank you. Got it.
ashishd
Hello @araongao2015,
It is always recommended to use IP XCI file while referencing IP and not the DCP file directly. You can check page #78 from below UG
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug896-vivado-ip.pdf
Ashish
araongao2015
Hi @ashishd:
  Thank you. Got it.
