Visitor waqarshahid
Adder and Shifter using Blocking and non-Blocking Assignments
My Question is related to synthesizes of my Verilog Code below is a module names as addshifter which when synthesis just make a shifter. please note i have used non-blocking statements. but the code shows that I am making a adder first and then a shifter that will shift the values of Areg. Now If I replace the non-blocking statement with the blocking statements. the Synthesizes tools makes an adder 4-bit and a 4-bit register shifter.
 I want to ask why is this so.... I could not fiqure it out why it works well with blocking assignments and not with non-blocking assignments. This was a test program I made to check. I was having a same problem while i was coding a multiplier of the add & shift type.
module addshifter(A,B,clk,rst)
input [3:0] A;
input clk,rst;
output [3:0] B;
reg [3:0] Areg;
assign B = Areg;
always @ (posedge clk or posedge rst)
begin
   if(rst)
       Areg <= A;
   else
       Areg <= Areg +1;
       Areg <= Areg <<1;
end
endmodule
Re: Adder and Shifter using Blocking and non-Blocking Assignments
The Verilog code is doing the proper action for a non-blocking assignment.  If you look at the
Verilog spec, the last non-blocking assignment in a block wins.  Thus
always @(posedge clk)
  begin
  A <= 1;
  A <= 0;
  end
will correctly assign the value of 0 to A both in simulation and synthesis.  Why?  Because for non-blocking,the last
assignment wins. Verilog performs the following operations at each time step:
  a) evaluate the Right Hand Side (RHS) of all non-blocking assignments and save the results in temporary variables.
  b) assign the temporary variables to the final variables.
This is a simplification, but gives you the general idea as to what is going on.
This method insures that operations like:
    begin
    A <= 0;
    B <= A;
    C <= B;
    D <= C;
    end
operate correctly.   Try simulating the above logic both with blocking & non-blocking assignments.  When you
understand why the two assignment styles work differently, you'll understand why your example works the
way it does.
A simple rule of thumb that many people follow *most* of the time is
   "always use non-blockig assignment in sequential (clocked) logic"
   "always use blocking assignments in  combinatorial logic"
but... rules are meant to be broken sometimes!
I hope this helps.  You really need to understand this fundamental the reason for the 2 different assignment styles.
John Providenza
  begin
  A <= 1;
  A <= 0;
  end
    begin
    A <= 0;
    B <= A;
    C <= B;
    D <= C;
    end
way it does.
John Providenza
