meguellatix
Adder tree using xilinx ip core
Hello everyone,
I have a theoritical question: I need to add , in 2'complement, 8 complex values, coded in fixed point 32_24 format. the first solution that poped out to my mind is to use the adder ip core to design an adder tree, after having done a unit 2x32 bits complex adder. the issue is I'm not quite comfortable with how 2's complement addition is done and not sure how to manage precision through the tree stages...now my question(s): is it possible to use the same complex adder  through all the stages, by choosing a precision that cover the final result? if not can any one suggest how to do it?
I appologize if this is not the right place for this question.
jmcclusk
Mentor
Mentor
Recursion is a nice solution to building adder trees.   I typically use a VHDL recursive adder that operates on a vector of values to add.    Dividing the vector by 2 gives a binary tree, and dividing into 3 pieces gives a ternary tree, which is more efficient in terms of logic, but a bit slower in Fmax.   In VHDL it's pretty easy, and Verilog 2005 standard specifies that module recursion is supported.
In VHDL, the tricky part is defining a data type that's extensible in 2 dimensions,  precision and vector length.   Here's an example in VHDL-2008:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.Numeric_Std.all;
package Add_Reduce is
type unsigned_array is array(natural range <>) of unsigned;
end package;
The data type "unsigned_array" is our port object for the input.  In your case, it would be an array of complex values.  Note that we need to manually compute the precision of the output.   In a perfect world this, would be computed by a function in this package, to make it easier to use.   Calculating output precision can be tricky, especially if the inputs aren't using the full range possible.    Extra functions such as saturation and clipping are left as an exercise for the reader.
Next, here is the recursive adder tree in VHDL-2008.  This one uses ternary adders in behavioral code, which may or may not synthesize correctly.  Sometimes Vivado is recalcitrant on the issue.   There's also a bit of code to detect the corner case when the input is an array of 1 bit unsigned values.
library IEEE;
use IEEE.NUMERIC_STD.ALL;
library xil_defaultlib;
use xil_defaultlib.Add_Reduce.all;
entity add_reduce_unsigned is
    Port ( clk : in STD_LOGIC;
           A : in unsigned_array;
           Q : out unsigned
end add_reduce_unsigned;
architecture Behavioral of add_reduce_unsigned is
component add_reduce_unsigned is
           Q : out unsigned
end component;
constant C_word_len : natural := A(A'high)'length;
begin
gen: case A'length generate
    when 1 | 2 | 3 =>               -- ternary addition is supported for Series 7 and higher
        proc: process(clk) is
        begin
        if rising_edge(clk) then
            if A'length = 1 then
                Q <= resize( A(A'low),Q'length);
            elsif A'length = 2 then
                Q <= resize( A(A'high),Q'length) + resize( A(A'low),Q'length);
            else
                Q <= resize( A(A'high),Q'length) + resize( A(A'high - 1),Q'length) + resize(A(A'low),Q'length);
            end if;
        end if;
        end process;
    when 4 | 5 | 6 =>
        gen_1bit: if A(A'high)'length = 1 generate   -- special case, when we are just adding bits instead of words
            begin
                if A'length = 4 then
                    Q <= resize(A(A'high),Q'length)+resize(A(A'high-1),Q'length)+resize(A(A'high-2),Q'length)+resize(A(A'low),Q'length);
                elsif A'length = 5 then
                    Q <= resize(A(A'high),Q'length)+resize(A(A'high-1),Q'length)+resize(A(A'high-2),Q'length)+resize(A(A'high-3),Q'length)+resize(A(A'low),Q'length);
                else
                    Q <= resize(A(A'high),Q'length)+resize(A(A'high-1),Q'length)+resize(A(A'high-2),Q'length)+resize(A(A'high-3),Q'length)+resize(A(A'high-4),Q'length)+resize(A(A'low),Q'length);
                end if;
            end if;
            end process;
        else generate
            signal tmp1, tmp2 : unsigned(Q'length-2 downto 0);
        begin
            g1: entity xil_defaultlib.add_reduce_unsigned
                port map( clk => clk,
                    A => A(A'high downto A'high - A'length/2 + 1),
                    Q => tmp1 );
            g2: entity xil_defaultlib.add_reduce_unsigned
                    A => A(A'high - A'length/2 downto A'low),
                    Q => tmp2 );
            begin
                Q <= resize(tmp1,Q'length) + resize(tmp2,Q'length);
            end if;
            end process;
        end generate gen_1bit;
    when others =>
        signal tmp1, tmp2, tmp3 : unsigned(Q'length-2 downto 0);
        begin
                    A => A(A'high downto A'high - A'length/3 + 1),
                    Q => tmp1 );
                    A => A(A'high - A'length/3 downto A'low + A'length/3),
                    Q => tmp2 );
            g3: entity xil_defaultlib.add_reduce_unsigned
                    A => A(A'low + A'length/3 - 1 downto A'low),
                    Q => tmp3 );
            begin
                Q <= resize(tmp1,Q'length) + resize(tmp2,Q'length) + resize(tmp3,Q'length);
            end if;
            end process;
end generate gen;
end Behavioral;
And finally a synthesis testcase to verify it works in Vivado synthesis.
library IEEE;
library xil_defaultlib; use xil_defaultlib.Add_Reduce.all; entity test_add is Port ( clk : in STD_LOGIC; dat_in : unsigned(31 downto 0); sum : out unsigned(42 downto 0)); end test_add; architecture Behavioral of test_add is signal A : unsigned_array(511 downto 0)(31 downto 0); begin proc: process(clk) is begin if rising_edge(clk) then for i in A'range loop -- just build a big shift register on A if i = 0 then A(i) <= dat_in; else A(i) <= A(i-1); end if; end loop; end if; end process; g1: entity xil_defaultlib.add_reduce_unsigned port map( clk => clk, A => A, Q => sum ); end Behavioral;
jmcclusk
Mentor
Mentor
library IEEE;
end package;
library IEEE;
           Q : out unsigned
           Q : out unsigned
end component;
begin
        begin
            else
            end if;
        end if;
        end process;
    when 4 | 5 | 6 =>
            begin
                else
                end if;
            end if;
            end process;
        else generate
        begin
                    Q => tmp1 );
                    Q => tmp2 );
            begin
            end if;
            end process;
    when others =>
        begin
                    Q => tmp1 );
                    Q => tmp2 );
                    Q => tmp3 );
            begin
            end if;
            end process;
end generate gen;
end Behavioral;
library IEEE;
drjohnsmith
For fixed point addition / subtraction, you gain one extra bit for each addition / subtraction.
these might be good pointers
https://www.allaboutcircuits.com/technical-articles/fixed-point-representation-the-q-format-and-addition-examples/
https://www.dsprelated.com/showarticle/139.php
markcurry
Not quite right - it's logarithmic - For N additions / subtractions, you add log2(N) bits.. I.e. Adding 8 quantities, you'll need log2(8) = 3 extra bits at the output.
Mark
meguellatix
hello jmcclusk, Thank you for your thourough answer! actuallyI was thinking of using the core, but if vhdl supports this "recursion" I will go for it, although I only know its name, no other details...one occasion to learn new things. just an other question if I may, in how many clock cycles is recursion adder tree slower compared to a conventional one?
thanks again!
meguellatix
hello drjohnsmith,
thank you for the link, it's very clearly explained and intuitive!
meguellatix
hi,
i think he meant one bit per stage...
