Adding signal to sensitivity list ruins the synthesis
I'm writing a simple D-flip-flop in Verilog and looking at what it synthesizes to. Here's what I have:
module d_flip_flop(
    input d,
    input clr,
    input clk,
    input ce,
    output reg q
always @(posedge clk) begin: d_flip_flop
    if (clr) begin
        q <= 1'b0;
    end else if (ce) begin
q <= d; end end endmodule
And it synthesizes to:
However, making this change to the code and adding CE to the sensitivity list:
module d_flip_flop(
    input d,
    input clr,
    input clk,
    input ce,
    output reg q
always @(posedge clk or posedge ce) begin: d_flip_flop
    if (clr) begin
        q <= 1'b0;
        q <= d;
    end
end
endmodule
It synthesizes to:
What is going on? Why would adding CE to the sensitivity list make this synthesize to a buffer?
Thanks!
Re: Adding signal to sensitivity list ruins the synthesis
This is one of those cases where Vivado should be giving a synthesis error. Instead it synthesizes without issue, even though it can't implement the desired logic.
"Why would adding CE to the sensitivity list make this synthesize to a buffer?"
means that clr is synchronous to both clk and ce, which can't be done on an FPGA. Your first code example is the correct way to code a flip-flop with synchronous reset and enable.
Hi @vivadouser67 ,
I agree with @steven_bellock  Vivado should have issued error. This can't be modelled in flop.
Btw, did you intend to put clr in senstitvity list
always@(posedge clk or posedge clr)
begin
 if(clr)
end
Ajay
First, adding CE in the sensitivity list is not a common way to describe an FF. This may be the reason why Vivado Synthesis gives the only-buffer result.
Second, please check the Synthesis log and see if it gives any message about this always statement. I would expect some messages in the log about this.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Your explanation makes perfect sense! It's sad to see the synthesis tool be so useless in this situation though. I'd say this is a bug.
The only warning I see is: "[Synth 8-3331] design d_flip_flop has unconnected port ce" which is pointless.
Thank you!
