nadaumtimuj
AirHDL register array import in VIVADO
I am using AirHDL to import IP to my vivado design. I am getting VHDL files from AirHDL. For a single register, it works fine on my project. But when I create a register array in AirHDL and then import it into my project, I receive the following error:
Port type 'slv32_array_t' is not recognized. Only std_logic and std_logic_vector types are allowed for ports. See the documentation for more details
Any solution? Thanks.
richardhead
What are you trying to import it to? If you import the HDL as is, then you shouldnt have a proble, assuming you have slv32_array_t in a package somewhere. But if its as a block design then you need to remember you can only use basic types in the block design connections (std_logic, std_logic_vector and integer is about all that works).
richardhead
nadaumtimuj
Yes, it is a block design. The AirHDL support team helped me to flatten the array in a wrapper which worked. Thanks.
