araongao2015
An issue about "use_dsp" with its value "logic"
Hi All,
In ug901, it shows messages about use_dsp like below.
Accepted values are: “logic”, “yes”, and “no”:
• The “logic” value is used specifically for XOR structures to go into the DSP
primitives. For “logic”, this attribute can be placed on the module/architecture level
only.
I write a VHDL module like below.
library ieee;
use ieee.std_logic_1164.all;
entity dsp_logic is
generic (
W : positive := 16
port (
clk : in std_logic;
ain : in std_logic_vector(W-1 downto 0);
bin : in std_logic_vector(W-1 downto 0);
pout : out std_logic_vector(W-1 downto 0)
end dsp_logic;
architecture archi of dsp_logic is
attribute use_dsp : string;
attribute use_dsp of archi : architecture is "logic";
signal ain_r : std_logic_vector(W-1 downto 0) := (others => '0');
signal bin_r : std_logic_vector(W-1 downto 0) := (others => '0');
begin
process(clk)
begin
if rising_edge(clk) then
ain_r <= ain;
bin_r <= bin;
pout <= ain_r xor bin_r;
end if;
end process;
end archi;
But actually, it does not work. Could someone give a clue?
maps-mpls
Mentor
Mentor
It looks like UG901 needs to be updated on a couple of fronts.  First, I could only get it to work with this:
  signal p_r  : std_logic_vector(oP'range)  := (others => '0');
  attribute use_dsp48        : string;
  attribute use_dsp48 of p_r : signal is "logic";
which contradicts UG901.  UG901 incorrectly states:
primitives. For “logic”, this attribute can be placed on the module/architecture level only.
Note that the UG912 states more restrictions than I could find in UG901:
• LOGIC: For UltraScale architecture only. Use the DSP blocks to implement large/wide XOR functions.
This is also wrong, because I got it to work in a Kintex 7S device.  See solution below.
Lastly, my solution does not work for XOR bit widths less than or equal to 35.  Only bit widths greater than or equal to 36 worked for me.  My search was not exhaustive for widths or 7S v. US/US+.
Toward helping Xilinx engineers better characterize the use_dsp attribute:
1. This did not work:
  attribute use_dsp48 of rtl : architecture is "logic";
2.  This did work, in contradiction to UG901, but only for specific bit widths
Hopefully somebody from Xilinx will be able to chime in here, and report that the documentation is being updated.
Here are a couple of test cases for the xilinx engineers, as well as others who might want to reverse engineer the attribute:
library ieee;
entity top is
generic (
  G_TW : positive := 36 -- 36 and 48 worked for me...35 and selected lower values did not
port (
  iCLK  : IN  std_logic;
  iA    : IN  std_logic_vector(G_TW-1 downto 0);
  iB    : IN  std_logic_vector(G_TW-1 downto 0);
  oP    : OUT std_logic_vector(G_TW-1 downto 0)
end top;
architecture RTL of top is
begin
dsp_logic_u1 : entity work.dsp_logic
generic map(
  G_W => iA'length
port map(
  iCLK => iCLK,
  iA   => iA,
  iB   => iB,
  oP   => oP
end RTL;
library ieee;
entity dsp_logic is
generic (
  G_W : positive := 48
port (
  iA    : IN  std_logic_vector(G_W-1 downto 0);
  iB    : IN  std_logic_vector(G_W-1 downto 0);
  oP    : OUT std_logic_vector(G_W-1 downto 0)
end dsp_logic;
architecture RTL of dsp_logic is
  signal a_r : std_logic_vector(iA'range)  := (others => '0');
  signal b_r : std_logic_vector(iB'range)  := (others => '0');
begin
  process(iCLK)
  begin
    if rising_edge(iCLK) then
      a_r <= iA;
      b_r <= iB;
      p_r <= a_r xor b_r;
    end if;
  end process;
  oP <= p_r;
end RTL;
Good luck everybody!
*** Destination: Rapid design and development cycles *** Unappreciated answers get deleted, unappreciative OPs get put on ignored list ***
maps-mpls
Mentor
Mentor
library ieee;
entity top is
generic (
port (
end top;
begin
generic map(
  G_W => iA'length
port map(
  iCLK => iCLK,
  iA   => iA,
  iB   => iB,
  oP   => oP
end RTL;
library ieee;
entity dsp_logic is
generic (
port (
end dsp_logic;
begin
  process(iCLK)
  begin
      a_r <= iA;
      b_r <= iB;
      p_r <= a_r xor b_r;
    end if;
  end process;
  oP <= p_r;
end RTL;
araongao2015
Hi @maps-mpls
Thank you very much!
maps-mpls
Mentor
Mentor
You are welcome @araongao2015, I'm glad I could help.
