01-12-2018 08:48 AM - edited 01-12-2018 10:36 AM
Vivado (2017.1 and 2017.3.1) throws the following exception when I run the post-synthesis simulation on my design:
ERROR: [Common 17-70] Application Exception: getAndUpdateDefaultGUIDesignGraph: nullptr supplied! while executing "get_files -compile_order sources -used_in synthesis_post -of_objects [get_filesets $a_sim_vars(s_simset)]" (procedure "usf_get_files_for_compilation_post_sim" line 80) invoked from within "usf_get_files_for_compilation_post_sim $global_files_str" (procedure "::tclapp::xilinx::xsim::usf_get_files_for_compilation" line 18) invoked from within "::tclapp::xilinx::xsim::usf_get_files_for_compilation global_files_str" (procedure "usf_xsim_setup_simulation" line 70) invoked from within "usf_xsim_setup_simulation" (procedure "tclapp::xilinx::xsim::setup" line 19) invoked from within "tclapp::xilinx::xsim::setup { -simset epu_tb -mode post-synthesis -type functional -run_dir /home/albert/git/proj/Vivado/proj/bran..." ERROR: [Vivado 12-4473] Detected error while running simulation. Please correct the issue and retry this operation.
The command which is run by Vivado is:
launch_simulation -simset epu_tb -mode post-synthesis -type functional
Does anyone has an idea about the reason or what could solve this issue? Thanks in advance!
01-15-2018 09:54 AM
It seems that the error occurred due to my simulation set configuration. I did not not "include all design sources for simulation", but just the necessary files for the test, which seemed to make the "get_files ..." command crash (as seen above). Is it always necessary to include all design sources when running post-synthesis or post-implementation simulations?
01-12-2018 10:50 AM
Hi @a_bert
Can you try running the launch_simulation from the tcl console with -noclean_dir option?
launch_simulation -simset epu_tb -mode post-synthesis -type functional -noclean_dir
Rohit
01-14-2018 05:18 AM - edited 01-14-2018 05:19 AM
Even with this "-noclean_dir" option the simulation does show any change and outputs the same.
01-14-2018 08:28 AM
Hi @a_bert,
Which OS are you using?
Does behavioural simulation result in same issue or does it run successfully?
Can you please share the archived project or a test case to reproduce and check this issue at our end.
Thanks & Regards,
Sravanthi B
01-15-2018 03:11 AM
I'm using Ubuntu 16.04.1 with Kernel 4.8.0-58. Behavioural Simulation runs without problems. I can't share the whole project and unfortunately have not figured out a minimal test case to reproduce this exception yet. Do you might have other idea what to try in order to get more information what could be the underlying issue?
01-15-2018 09:54 AM
