mohamad
Assignment under multiple single edges is not supported for synthesis
Hello every body
I want to make a shift register in simulator ISE but when I writing the following code i get tht "Assignment under multiple single edges is not supported for synthesis" error
any answer i will appreciate that
bruce_karaffa
Are you trying to assign a value to a signal on both teh rising edge and falling edge of a clock?  You cannot do this.  There are no DDR registers in the FPGA fabric, only on the output tiles.
bruce_karaffa
