doner_t
Axi lite register default value assigning
I constructed a custom ip with one Axi-Lite slave interface.I want to give some default values into some signals(say some registers).
Then, I wrote a VHDL process as like below in the user logic part of custom Axi-Lite ip template.
If rising edge( S_Axi_Clk)
If S_Axi_Aresetn = '0'
Write Some default values into some signals
else
Write slave register values into some signals
end
So I want to give my default values into registers when Axi-Lite reset assert.  I am assuming the axi-lite will be reset,  when FPGA power up.
Does my aproach is true to give some default values into signal?
I read the my default values from another register in SDK. ups. They are not my default values. so I could not give default values.
how can I solve this problem, any idea ?
keisn13
Hi. Maybe you do somthing wrong in case stament of access the registers. Can you show sdk code and you custom ip code?
anusheel
@doner_t
Can you show us the custom IP interface details and register values? It would be helpful if you can share the custom IP here.
Anusheel
Helpful answer -> Give Kudos
doner_t
Firstly thank you.
I open the SDK , with a hello world application, to see only register values of my custom ip. I am waiting to see some default values that I assigned in VHDL in registers.
I have an AXI-Lite template generated from Vivado.
Basicly, I added below  process under the user logic part in Axi Lite template
process (S_AXI_ACLK, S_AXI_ARESETN) is
begin
if(rising_edge(S_AXI_ACLK)) then
 if S_AXI_RESETN = '0' then
    signal1 <= '1';    -- default value for signal1.
    signal2 <= '1'     -- default value for signal2
    signal3 <= '0'    -- default value for signal3
else
    signal1 <= slv_reg0(0);    -- write to this signal.
    signal2 <= slv_reg0(1)     -- write to this signal
    signal3 <= slv_reg0(2)     -- write to this signal
end if;
end if;
end process
I have a sub-modul here. signal1, signal2 and signal3 go through to this sub-modul as input.
entity sub_modul is
port(
     input1  :in std_logic;
     input2  :in std_logic;
     input3  :in std_logic;
     output1 : out std_logic;
     output2 : out std_logic;
     output3 : out std_logic;
end sub_modul;
architecture Behavioral of sub_modul is
begin
  process(input1)
    begin
       case input1 is
        when '1' =>
           output1 <= '0'
        when '0' =>
          output1 <= '1'
      end case;
end process;
process(input2)
    begin
       case input2 is
        when '1' =>
           output2 <= '0'
        when '0' =>
          output2 <= '1'
      end case;
end process;
process(input3)
    begin
       case input3 is
        when '1' =>
           output3 <= '0'
        when '0' =>
          output3 <= '1'
      end case;
end process;
end Behavioral ;
And then this sub-modul gives 3 output. I can read the these three outputs from another axi-lite register.(say slv_reg1). Such as output1 value into slv_reg1(0),   output2 value into slv_reg1(1), output3 value into slv_reg1(2).
When FPGA  power-up and then, I run the hello application basicly, immediately look at the my read register(slv_reg1).
I am waiting to see 001 in slv_reg1(in hex 0x00000001) in SDK memory, because of my default values correspondg to this value in the sub-modul.
But I saw the 111 in slv_reg1 (in hex 0x00000007) in SDK memory. Ups. My default value assigning did not work. I could see from this result signal1, signal2, signal3 started with logic '0' when FPGA power-up, without my default values. Problem is here.
I can change the slv_reg1 values with entering some values into slv_reg0 in SDK. It is OK. I works correctly.
But I need also some correct default values in slv_reg1 when FPGA power-up.
Best regards,
