[BD 41-1031] Hdl Generation failed for the IP Integrator design
I am using vivado 2016.2 for block design. When I edit my block design (basically, adding some new blocks and deleting some old blocks), the error popped up out of no reason. Anyone can help me to debug the problem?
Re: [BD 41-1031] Hdl Generation failed for the IP Integrator design
After I included all the addressable segments, the error is gone.
are you using xilinx dpd core . check if ip correctly added in your ip catalog
Thanks and Regards
Balkrishan
@linwei8
Can you try rebuilding the block design by using bd.tcl file? Also, check log if tool is issuing any important message before failing with an error.
Anusheel
Helpful answer -> Give Kudos
