10-21-2020 08:57 PM
Vivado can correctly infer READ_FIRST memory with byte selectable write enable signals
architecture rtl of RAM_single_port is
subtype memory_cell_type is std_logic_vector(8 * width_in_bytes - 1 downto 0);
type ram_chip_type is array (0 to depth - 1) of memory_cell_type;
begin
portA: process is
variable ram : ram_chip_type;
begin
wait until rising_edge(clk);
-- read
douta <= ram(addra);
-- write
for i in 0 to width_in_bytes - 1 loop
if wea(i) = '1' then
ram(addra)(8 * i + 7 downto 8 * i) := dina(8 * i + 7 downto 8 * i);
end if;
end loop;
end process;
end architecture;
but if the logic is changed slightly to WRITE_FIRST
portA: process is
begin
-- write
end if;
end loop;
-- read
end process;
Vivado can no longer infer the RAM, and reports
[Synth 8-2914] Unsupported RAM template
Yet WRITE_FIRST with byte selectable write enable signals is a supported RAM type within the IP library
10-23-2020 07:13 AM
Please refer to the below example of Byte-write with WRITE_FIRST(page no. 134):
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug901-vivado-synthesis.pdf
Anusheel
10-22-2020 02:54 PM
Grateful for any suggestions...?
10-23-2020 07:13 AM
Anusheel
10-23-2020 04:48 PM
Thank you Anusheel, that is a great guide!
