[BUG] Can't connect an array of nested struct-s to an instance array
Hello!
I have a problem with Vivado 2019.2 synthesis (behavioral simulation works as expected). I have a module instance array, where the ports are connected to arrays of their respective types, expecting each module instance to pick up the corresponding array element. This used to work fine, but recently I modified the type of one of the ports, which became a struct containing another struct. Simulation continued to work, but I get an error during synthesis.
Minimal example (System Verilog):
typedef struct {
  logic c;
} B;
typedef struct {
  B b;
  //logic b;
} A;
module Mymodule(
  input A a
endmodule
module Top(
  A a;
  Mymodule mymodule (
    .a(a)
  A aa[0:9];
  Mymodule mymodules[0:9] (
    .a(aa)
endmodule
synth_design gives me:
ERROR: [Synth 8-448] named port connection 'a[b[c]]' does not exist for instance 'mymodules' of module 'Mymodule' [xxx.sv:26]
Connecting a single (non-array) instance is fine. Replacing the "B b" definition with "logic b" to eliminate the struct-in-struct also works. Please confirm if this is a bug. Cheers.
Hi @GP
Yes, this is a bug in Vivado synthesis with array of module instance with nested struct port.
Will report this to get fixed in future release.
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
Hi @GP
-Shreyas
Thanks. It seems that a "generate for" can be a straightforward workaround for this, but a fix would be even better.
