nhenri
BUG: SystemVerilog import scope is not respected
In Vivado, the import scope is not respected, meaning there is conflict between package even if not imported.
Here's an example (code also in attachment):
This example declare 2 separate package with a typedef struct of the same name (ts).
The synthesis FAIL because in toto.sv it's use the 'ts' from tata_pkg.sv.
You have to specify the package even if only 'ts' from toto_pkg.sv is visible.
These mean you have to check every package to ensure all name are unique
Is this the behavior wanted or a bug ?
Thank you
aher
Hi @nhenri,
Can you please run vivado in single file compilation unit using -sfcu switch in synthesis settings more options
This will scope the declaration only within corresponding file.
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
aher
Hi @nhenri
This looks like an issue in synthesis as only imported packages should be visible in the module. I will follow up on this and keep you posted.
Shreyas
aher
Hi @nhenri,
-Shreyas
nhenri
Oh thank!
I'm surprise this option is not set by default.
markcurry
Be careful with importing things into the global scope, as you are doing.   My two cents - this is bad form, and pollutes the global name space.  Almost all of the examples in the SystemVerilog spec shows package imports into a specific scope - be it a module, interface, or another package.
By importing into the global scope - especially when using wildcards - one needs to start delving into some rather detailed corners of the spec to fully understand the full scope resolution, and the impact of colliding names.  I'd avoid this mess altogether, unless there were very weird problems you were trying to solve, and you didn't have another method.
Mark
nhenri
Oh, yes you're right, I didn't realize it.
I mostly do VHDL where you import globally
Note: that if I put the import inside the module toto, I don't see the issue
Thank you for your comment !
