Newbie aalmont0
Basys 3 Seven Segment Display issue
Hey all,
I'm new to VHDL and attempting to program my board to display hex on the seven segment display using switches. I've managed to get the numbers to appear on the display, but have ran into two problems. I'd like the numbers to appear only on one display, not all of them. I thought setting "an <= "1110";" in the top file would give the desired result but I must be missing something. The second problem I'm having is activating btnC should display a negative sign, but doesn't. I tried port mapping negative to btnC and that didn't work. I've been troubleshooting for hours, any assistance would be greatly appreciated. Thanks!
sevenSegDecoder
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity sevenSegDecoder is
    Port ( sw       : in STD_LOGIC_VECTOR (3 downto 0);
           seg      : out STD_LOGIC_VECTOR (0 to 6);
           negative : in STD_LOGIC);
end sevenSegDecoder;
architecture Behavioral of sevenSegDecoder is
begin
    process(sw)
        begin
        if negative='1' then
            case sw is
                   when "0000" => seg <= "0000001"; --0
                   when "0001" => seg <= "1001111";
                   when "0010" => seg <= "0010010";
                   when "0011" => seg <= "0000110";
                   when "0100" => seg <= "1001100";
                   when "0101" => seg <= "0100100";
                   when "0110" => seg <= "0100000";
                   when "0111" => seg <= "0001111";
                   when "1000" => seg <= "0000000";
                   when "1001" => seg <= "0001100";
                   when "1010" => seg <= "0001000";
                   when "1011" => seg <= "1100000";
                   when "1100" => seg <= "0110001";
                   when "1101" => seg <= "1000010";
                   when "1110" => seg <= "0110000";
                   when "1111" => seg <= "0111000"; --F
    end case;
    end if;
end process;
end Behavioral;
Top file
library IEEE;
entity topSevenSeg is
           btnC : in STD_LOGIC;
           an : out STD_LOGIC_VECTOR (3 downto 0)
end topSevenSeg;
architecture Behavioral of topSevenSeg is
    component sevenSegDecoder
    port (
    end component;
begin
    an <= "1110";
ins: sevenSegDecoder port map (
            sw => sw,
            seg => seg,
            negative => btnC
end Behavioral;
Constraints
#switches
set_property PACKAGE_PIN V17 [get_ports {sw[0]}]
set_property PACKAGE_PIN V16 [get_ports {sw[1]}]
set_property PACKAGE_PIN W16 [get_ports {sw[2]}]
set_property PACKAGE_PIN W17 [get_ports {sw[3]}]
#segment display
set_property PACKAGE_PIN W7 [get_ports {seg[0]}]
set_property PACKAGE_PIN W6 [get_ports {seg[1]}]
set_property PACKAGE_PIN U8 [get_ports {seg[2]}]
set_property PACKAGE_PIN V8 [get_ports {seg[3]}]
set_property PACKAGE_PIN U5 [get_ports {seg[4]}]
set_property PACKAGE_PIN V5 [get_ports {seg[5]}]
set_property PACKAGE_PIN U7 [get_ports {seg[6]}]
set_property PACKAGE_PIN U2 [get_ports {an[0]}]
set_property PACKAGE_PIN U4 [get_ports {an[1]}]
set_property PACKAGE_PIN V4 [get_ports {an[2]}]
set_property PACKAGE_PIN W4 [get_ports {an[3]}]
#buttons
set_property PACKAGE_PIN U18 [get_ports btnC]
Re: Basys 3 Seven Segment Display issue
@aalmont0
Did you verify the functionality with a testbench? If not, please create a testbench and test the functionality of the RTL code.
Anusheel
Anusheel
