krn-krn
Bi-directional Data_Bus
inout [23:0] data_bus;
assign data_bus=(!ms0)?((addr_bus==24'h000063)?data_reg_4:data_bus):24'bzzzzzzzzzzzzzzzzzzzz;
If ms0==0 and addr_bus==24'h000063 ,data_reg will assign to data_bus,after this  ms0==0 and if I get a different address ,will data_bus overwrites old data or will it assign new data which comes on data_bus?
viviany
I would suggest you run a simulation to get the answer.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
