Buffers in a synthesized design.
Below figure is the elaborated design.
When I synthesize the design, the synthesized schematic looks like below figure.
At the input, 2 buffers(IBUF) appeared. I don't know why these buffers appeared even though I didn't added in my VHDL code.
Why do I need these buffers and why does the synthesizers added these buffers? Can't just inputs go directly into the LUT?
Thanks for your help.
Re: Buffers in a synthesized design.
@kimjaewon
These are Input buffers which are automatically added by synthesis. Signals used as inputs to 7 series devices must use an input buffer (IBUF).
Check this link:
https://forums.xilinx.com/t5/General-Technical-Discussion/What-s-the-necessity-to-use-ibuf-component/td-p/139442
--SYed
