Bug in systemverilog synthesis?
Synthesizing the SV code below, in Vivado 2019.2:
module test_one(
  input logic a,
  input logic b,
  input logic c,
  output logic always_d,
  output logic always_comb_d);
  function logic my_func(input logic m_c);
    my_func = a | b | m_c;
  endfunction : my_func
  always @*
    always_d = my_func(c);
  always_comb
    always_comb_d = my_func(c);
endmodule
results in the following design:Design.PNG
so both always have the same truth table which is wrong. Is this a known bug in Vivado?
Re: Bug in systemverilog synthesis?
Hi @tii.hardware.developer.1 ,
For synthesis, here, always@* and always_comb both are same.
Hence o/p is tied to same driver.
Ajay
Ajay
It is a result of logic sharing optimization.
For the functions that generate the same result, only one of them is kept and the other one is removed.
If you'd like to keep both, you can add "keep" or "dont_touch" attributes.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Thanks @apetley, I was not aware of this behavior when synthesizing the always@* and always_comb with the Xilinx toolchain.
Hi @viviany,
After @apetley's answer that makes sense, otherwise the optimization you mentioned could not be applied (i.e., the two outputs would not be always the same).
@tii.hardware.developer.1 I am confused. Why do you think the truth tables would be different based on always_comb versus always @*?
