Bugs in Vivado 2014.1
I've reported a couple of Vivado and Xsim 2013.4 bugs in december 2013. I've now tested with Vivado 2014.1 and my test cases still fail, some with slightly different errors:
http://forums.xilinx.com/t5/Synthesis/Strange-output-const-zero-bug-with-Vivado-gt-gt-gt-signedness/td-p/401411
Does not return constant 0 anymore. But sign extension is done incorrectly. It shopuld return 1111 for a=1 and b=0 but returns 0001 instead.
http://forums.xilinx.com/t5/Synthesis/Vivado-creates-netlist-with-inputs-shorted-together/td-p/397161
Does not short together the inputs anymore but still returns an invalid circuit. For example a=63 and b=15 yields y0=7, but y0 should obviously be set to constant 0.
http://forums.xilinx.com/t5/Synthesis/Vivado-GDpGen-implementDivMod-DFNode-bool-Assertion-TBD-failed/td-p/401721
Still fails with the same assert.
http://forums.xilinx.com/t5/Synthesis/Vivado-bug-in-undef-handling-for-relational-operators/td-p/403469
Still same faulty behavior.
http://forums.xilinx.com/t5/Simulation-and-Verification/Bug-in-XSIM-when-combining-reduce-op-and-signed-unsigned/td-p/406801
http://forums.xilinx.com/t5/Simulation-and-Verification/XSim-implements-0-1-incorrectly/td-p/406517
http://forums.xilinx.com/t5/Simulation-and-Verification/XSim-hangs-on-power-operations-with-large-exponents/td-p/406887
What is the status of those? When can I expect fixes? I have more bug reports pending but are holding back on reporting them until the ones I already reported are fixed so I don't send in duplicates.
Hi Clifford,
I will re-look at the posts and will update you on them.
Achutha
Hi Clifford,
I have looked at the synthesis bug reported and i see they are not completely fixed.I am currently checking for the CR details.
I am also following up with the simulation bug.
I will keep you posted.
Achutha
Hi Clifford,
The simulation posts will taken care by simulation moderator and will be updated in the respective posts.
http://forums.xilinx.com/t5/Simulation-and-Verification/Bug-in-XSIM-when-combining-reduce-op-and-sig...
http://forums.xilinx.com/t5/Simulation-and-Verification/XSim-hangs-on-power-operations-with-large-ex...
Achutha
Hi Clifford
Thanks for sharing your feedback and reporting this to us.Xilinx is committed to any bugs or feedback reported.
We are actively following on these posts so that we could share updates or file bugs if they havent been done yet.
Sikta
Hi Clifford,
Summary/status of the synthesis issue posted :
Issue:1
http://forums.xilinx.com/t5/Synthesis/Strange-output-const-zero-bug-with-Vivado-gt-gt-gt-signedness/...
CR filed: CR#799204
Current Status: set for a fix in 2014.3
Issue:2
http://forums.xilinx.com/t5/Synthesis/Vivado-creates-netlist-with-inputs-shorted-together/td-p/39716...
CR filed :CR#799205
Current status:Set  for a fix in 2014.3
Issue:3
http://forums.xilinx.com/t5/Synthesis/Vivado-GDpGen-implementDivMod-DFNode-bool-Assertion-TBD-failed...
Issue fixed in 2014.2 latest build.
Issue:4
http://forums.xilinx.com/t5/Synthesis/Vivado-bug-in-undef-handling-for-relational-operators/td-p/403...
Achutha
