mzannerni_zx
Bundling array ports on RTL viewer
I have an array signal connecting between two entities in the design.
TYPE Data_buffer IS ARRAY(127 DOWNTO 0) of STD_LOGIC_VECTOR(7 DOWNTO 0);
The RTL viewer shows each index as a separate signal which makes the rtl looks bad, is there anyway to bundle the array in one wide line in rtl viewer?
Mahmoud
