Visitor headspin
Can I redistribute the code inside the Language Template?
I am writing modules using chisel3, which is a DSL for hardware and convert the code into Verilog to be used by Vivado.
However, in chisel3, the initial block for BRAM is not supported.
So now I have to use the BRAM Verilog code from language template window in Vivado.
Now I wonder if I am permitted to use the language template outside of Vivado in my chisel3 project? And I wonder if it is legal to publish the project with the BRAM Verilog code?
Re: Can I redistribute the code inside the Language Template?
Hi @headspin
UG 901 has various BRAM examples for its inference in Vivado. You can use it in your project.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug901-vivado-synthesis.pdf
(Page 74, click on link and download the zip)
Regarding the legal thing, you might need to ask your FAE. I am not sure about it because we do handle technical issues here.
hemangd
Hi @headspin
hemangd
