Can i use elaborated design's schematic? instead of synthesis schematic
Hello Guys
For some days I failed to implement the arbiter puf. I expect the cause to be in optimization.
I think there is no problem with elaborated design's schematic.
But there seems to be some distortion in the systhesis schematic.
I want to generate a bitstream with elaborated design's schematic.
Is there an option to set it?
Re: Can i use elaborated design's schematic? instead of synthesis schematic
Vivado don' t have Schematic Editor
check this post for detail explanation
https://forums.xilinx.com/t5/Synthesis/what-exactly-is-elaborating-a-design/td-p/682043
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
