I tried upgrading my Vivado version from 2018.3 to 2019.2 a few days ago and after going through the simple process of upgrading my IP cores, I can no longer synthesize my project. It generates a failure indicating the following:
Abnormal program termination (EXCEPTION_ACCESS_VIOLATION)
Please check 'C:/Users/drichardson.POLARIS/Firmware/Spartan 7 Template/Spartan 7 Template.runs/synth_2/hs_err_pid10804.log' for details
Here is a WinDbg printout of the stack trace of the logfile:
Microsoft (R) Windows Debugger Version 10.0.18362.1 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\drichardson.POLARIS\Firmware\Spartan 7 Template\Spartan 7 Template.runs\synth_2\hs_err_pid10804.dmp]
User Mini Dump File: Only registers, stack and portions of memory are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Version 17763 MP (8 procs) Free x64
Product: WinNt, suite: SingleUserTS
17763.1.amd64fre.rs5_release.180914-1434
Machine Name:
Debug session time: Wed Jan 22 08:18:43.000 2020 (UTC - 8:00)
System Uptime: not available
Process Uptime: 0 days 0:00:46.000
This dump file has an exception of interest stored in it.
The stored exception information can be accessed via .ecxr.
(2a34.2990): Access violation - code c0000005 (first/second chance not available)
For analysis of this file, run !analyze -v
ntdll!NtGetContextThread+0x14:
00007ff8`9d3e14d4 c3 ret
0:004> !analyze -v
* Exception Analysis *
KEY_VALUES_STRING: 1
Key : AV.Fault
Value: Read
Key : Timeline.Process.Start.DeltaSec
Value: 46
PROCESSES_ANALYSIS: 1
SERVICE_ANALYSIS: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
Timeline: !analyze.Start
Time: 2020-01-22T16:20:34.651Z
Diff: 111651 mSec
Timeline: Dump.Current
Time: 2020-01-22T16:18:43.0Z
Diff: 0 mSec
Timeline: Process.Start
Time: 2020-01-22T16:17:57.0Z
Diff: 46000 mSec
DUMP_CLASS: 2
DUMP_QUALIFIER: 400
CONTEXT: (.ecxr)
rax=00000000fffffffc rbx=0000000000000000 rcx=000001baaf246170
rdx=000001baad2836e0 rsi=00000000ffffffff rdi=0000007fcadef468
rip=00007ff80f0b3c73 rsp=0000007fcadef278 rbp=00000000fffffffd
r8=000000000c30c30c r9=0000000000000003 r10=000001baad27b010
r11=0000000000000000 r12=000001baaf2462c0 r13=000001baaf246170
r14=0000000000000003 r15=000001baaf246170
iopl=0 nv up ei pl nz na po nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010206
librdi_synth!HARTResynthMgr::~HARTResynthMgr+0x193:
00007ff8`0f0b3c73 4a8b04c2 mov rax,qword ptr [rdx+r8*8] ds:000001bb`0eae4f40=????????????????
Resetting default scope
FAULTING_IP:
librdi_synth!HARTResynthMgr::~HARTResynthMgr+193
EXCEPTION_RECORD: (.exr -1)
ExceptionAddress: 00007ff80f0b3c73 (librdi_synth!HARTResynthMgr::~HARTResynthMgr+0x0000000000000193)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: 000001bb0eae4f40
Attempt to read from address 000001bb0eae4f40
DEFAULT_BUCKET_ID: INVALID_POINTER_READ
PROCESS_NAME: vivado.exe
FOLLOWUP_IP:
READ_ADDRESS: 000001bb0eae4f40
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 000001bb0eae4f40
WATSON_BKT_PROCSTAMP: 5d69ed50
WATSON_BKT_MODULE: librdi_synth.dll
WATSON_BKT_MODSTAMP: 5dd6f5ff
WATSON_BKT_MODOFFSET: e3c73
BUILD_VERSION_STRING: 17763.1.amd64fre.rs5_release.180914-1434
MODLIST_WITH_TSCHKSUM_HASH: d8d6fdb38bf78bb379cd4d609c36fbc951bec3be
MODLIST_SHA1_HASH: 298f085abaad6846b1c00aa4377352741dbcbf99
DUMP_FLAGS: 0
DUMP_TYPE: 2
ANALYSIS_SESSION_HOST: LAVSA2
ANALYSIS_SESSION_TIME: 01-22-2020 08:20:34.0651
ANALYSIS_VERSION: 10.0.18362.1 amd64fre
THREAD_ATTRIBUTES:
BUGCHECK_STR: APPLICATION_FAULT_INVALID_POINTER_READ
PRIMARY_PROBLEM_CLASS: APPLICATION_FAULT
PROBLEM_CLASSES:
Type: [@ACCESS_VIOLATION]
Class: Addendum
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0x2990]
Frame: [0] : librdi_synth!HARTResynthMgr::~HARTResynthMgr
Type: [INVALID_POINTER_READ]
Class: Primary
Scope: DEFAULT_BUCKET_ID (Failure Bucket ID prefix)
BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0x2990]
LAST_CONTROL_TRANSFER: from 00007ff810373aab to 00007ff80f0b3c73
STACK_TEXT:
0000007f`cadef278 00007ff8`10373aab : 000001ba`af2462c8 00000000`fffffffd 00000000`00000004 0000007f`cadef468 : librdi_synth!HARTResynthMgr::~HARTResynthMgr+0x193
0000007f`cadef280 00007ff8`0fc2ffab : 000001ba`af2462c8 0000007f`cadef468 0000007f`cadef3e0 00000000`00000005 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x8f697b
0000007f`cadef2e0 00007ff8`0fc26fe6 : 0000007f`cadef780 00007ff8`0fc24f01 000001ba`a8550f50 000001ba`a855ed50 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x1b2e7b
0000007f`cadef520 00007ff8`0fc27fe0 : 000001ba`addda210 0000007f`cadef650 000001ba`a855ed50 ffffffff`fffffffe : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x1a9eb6
0000007f`cadef5a0 00007ff8`0fc276b2 : 000001ba`b1503d80 0000007f`cadef650 0000007f`cadef6a9 0000007f`cadef780 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x1aaeb0
0000007f`cadef610 00007ff8`0fc206d7 : 000001ba`b15045a0 000001ba`00000006 000001ba`00000001 000001ba`b1504740 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x1aa582
0000007f`cadef710 00007ff8`0fc20080 : 00000000`00000000 000001ba`9caade60 000001ba`b6836dd0 00000000`00000013 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x1a35a7
0000007f`cadef990 00007ff8`0fc27254 : 000001ba`b6836dd0 000001ba`9caade60 000001ba`addda120 00000000`00000000 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x1a2f50
0000007f`cadefa70 00007ff8`0fc2b71b : 000001ba`9dac1030 0000007f`cadefbe0 0000007f`cadefbe0 000001ba`ae3dda40 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x1aa124
0000007f`cadefae0 00007ff8`0fc2a477 : ffffffff`ffffffff 00007ff8`9d35267d 000001ba`00000001 000001ba`abc24180 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x1ae5eb
0000007f`cadefde0 00007ff8`0fc21335 : 00000000`00000000 0000007f`cadf0348 000001ba`b6836dd0 00000000`00000000 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x1ad347
0000007f`cadf00e0 00007ff8`0fe7b421 : ffffffff`fffffffe 00000000`00000000 000001ba`abc24a20 0000007f`cadf0348 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x1a4205
0000007f`cadf0120 00007ff8`0fd6e109 : 000001ba`b6837c40 000001ba`a7d64c00 00000000`00000001 00000000`00000000 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x3fe2f1
0000007f`cadf0150 00007ff8`0fcc371f : 000001ba`a7d64c00 000001ba`a855cc50 000001ba`b6041d30 000001ba`b44554e0 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x2f0fd9
0000007f`cadf0340 00007ff8`0fcc38b9 : 00000000`00000000 000001ba`b3828520 00000000`00000000 000001ba`a7d64c88 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x2465ef
0000007f`cadf03c0 00007ff8`0fcc3690 : 000001ba`9caa1b38 000001ba`9be68d40 000001ba`b38285e0 000001ba`b6545cb0 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x246789
0000007f`cadf0480 00007ff8`0fcc38b9 : 00000000`00000000 000001ba`9caa1b30 000001ba`b603fd80 00007ff8`00000014 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x246560
0000007f`cadf0500 00007ff8`0fcc3b46 : 000001ba`9be67900 00000000`00000000 000001ba`9caa15f0 000001ba`b45c2830 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x246789
0000007f`cadf05c0 00007ff8`0fcc3e3c : 000001ba`9ab2f4d0 000001ba`b1b5c300 00000000`00000000 0000007f`cadf0670 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x246a16
0000007f`cadf0620 00007ff8`0fbd5ba1 : 000001ba`00000000 000001ba`b1f61ac0 00000000`00000000 00000000`00000000 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x246d0c
0000007f`cadf06b0 00007ff8`0fd6c87a : 000001ba`a7d64c00 000001ba`a93d78a0 000001ba`b6830b60 000001ba`00000002 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x158a71
0000007f`cadf0950 00007ff8`0fd6f914 : 000001ba`00000000 0000007f`cadf0a40 000001ba`92f0a160 00000000`00000000 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x2ef74a
0000007f`cadf0a20 00007ff8`0fd6cc80 : 000001ba`92f0a168 00000000`00000000 000001ba`8236e0c0 00000000`00000000 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x2f27e4
0000007f`cadf0a60 00007ff8`0fbd5b99 : 000001ba`a93d78a0 000001ba`00000001 00000000`00000000 00000000`00000000 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x2efb50
0000007f`cadf0b10 00007ff8`0fd6c87a : 000001ba`a7d61a80 000001ba`a93d78a0 000001ba`923668d0 000001ba`00000002 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x158a69
0000007f`cadf0db0 00007ff8`0fd6f914 : 000001ba`00000000 0000007f`cadf0ea0 000001ba`abf0b2f0 00000000`00000000 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x2ef74a
0000007f`cadf0e80 00007ff8`0fd6cc80 : 000001ba`abf0b2f8 00000000`00000000 000001ba`8236e0c0 00007ff8`0000001b : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x2f27e4
0000007f`cadf0ec0 00007ff8`0fbda3a0 : 000001ba`a93d78a0 00000000`00000001 00000000`00000000 000001ba`8236e080 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x2efb50
0000007f`cadf0f70 00007ff8`0fbb78ac : 000001ba`b1f64e50 000001ba`b1f64ed8 0000007f`cadf1098 00000000`00000000 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x15d270
0000007f`cadf0fa0 00007ff8`0fbb8482 : 0000007f`cadf1098 000001ba`923668d0 0000007f`cadf1160 000001ba`b1f64e50 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x13a77c
0000007f`cadf1000 00007ff8`0f207184 : 000001ba`a93d78a0 000001ba`b13749b0 000001ba`a93d78a0 00000000`00000000 : librdi_synth!HARTSynthProcessScheduler::updateGenomeEncodeNames+0x13b352
0000007f`cadf1060 00007ff8`0f20422c : 000001ba`ad5e91a0 00007ff8`10d5a360 000001ba`f489ff00 00007ff8`10d89e80 : librdi_synth!HARTFeasibilityDB::Instance+0x1ba94
0000007f`cadf1390 00007ff8`0f3275a3 : 00007ff8`10d5a360 fefefefe`00000000 00000000`00000000 000001ba`f489ff00 : librdi_synth!HARTFeasibilityDB::Instance+0x18b3c
0000007f`cadf13c0 00007ff8`0f3f5bc7 : 000001ba`b10fb690 00000000`00000002 00000000`00000002 ffffffff`ffffffff : librdi_synth!Synth_Realtime_Init+0x5dd83
0000007f`cadf1410 00000000`641f11fc : 00000000`642f5a20 00000000`00000000 000001ba`abd64600 00000000`642bac3c : librdi_synth!Realtime_Init+0x2487
0000007f`cadf17d0 00000000`641f218e : 00000000`00000000 000001ba`00000002 000001ba`f489ff00 000001ba`abd64600 : tcl85t!Tcl_ListMathFuncs+0x58c
0000007f`cadf1880 00000000`641f2e0f : 000001ba`f48996e0 000001ba`abd64600 00000000`00000002 00000000`00000002 : tcl85t!Tcl_EvalEx+0x99e
0000007f`cadf19b0 00000000`641fadca : 00000000`00000000 000001ba`f489fbf8 00000000`00000001 00000000`00000002 : tcl85t!TclEvalObjEx+0x32f
0000007f`cadf1a20 00000000`641f11fc : 000001ba`f489fbf8 000001ba`f48996e0 000001ba`f48996e0 00000000`00000000 : tcl85t!TclDumpMemoryInfo+0x33fa
0000007f`cadf1a60 00000000`64236238 : 000001ba`00000000 00000000`00000002 000001ba`f489fbf8 ffffffff`ffffffff : tcl85t!Tcl_ListMathFuncs+0x58c
0000007f`cadf1b10 00000000`64234fec : 000001ba`f48996e0 000001ba`808c2490 00000000`00000000 000001ba`00000000 : tcl85t!Tcl_ExprObj+0x1868
0000007f`cadf2110 00000000`641f2e8d : 000001ba`b4760e70 000001ba`f48996e0 000001ba`f82f6570 00000000`64271585 : tcl85t!Tcl_ExprObj+0x61c
0000007f`cadf2160 00000000`641f2acd : 000001ba`f48852f0 00000000`00000003 000001ba`f48996e0 000001ba`f4895f10 : tcl85t!TclEvalObjEx+0x3ad
0000007f`cadf21d0 00007ff8`408cfd8b : 000001ba`f489fb88 000001ba`f2a98020 000001ba`b4760e70 00000000`64284790 : tcl85t!Tcl_EvalObjEx+0x1d
0000007f`cadf2210 00000000`641f11fc : 000001ba`f48996e0 000001ba`f48996e0 000001ba`f489fb88 00000000`642bac7d : librdi_commontasks+0x1fd8b
0000007f`cadf2290 00000000`64236238 : 000001ba`00000000 00000000`00000003 000001ba`f489fb88 ffffffff`ffffffff : tcl85t!Tcl_ListMathFuncs+0x58c
0000007f`cadf2340 00000000`642812f4 : 000001ba`f48996e0 000001ba`86695080 000001ba`f489f9f8 00000000`00000000 : tcl85t!Tcl_ExprObj+0x1868
0000007f`cadf2940 00000000`641f11fc : 00000000`00000000 000001ba`f48996e0 000001ba`f489f9f8 00000000`642f61c0 : tcl85t!TclObjInterpProcCore+0x74
0000007f`cadf2990 00000000`64236238 : 000001ba`00000000 000001ba`00000001 000001ba`f489f9f8 ffffffff`ffffffff : tcl85t!Tcl_ListMathFuncs+0x58c
0000007f`cadf2a40 00000000`64234fec : 000001ba`f48996e0 000001ba`ad5eb150 00000000`00000000 000001ba`00000000 : tcl85t!Tcl_ExprObj+0x1868
0000007f`cadf3040 00000000`641f2e8d : 000001ba`b4760e70 000001ba`f48996e0 0000007f`00000003 0000007f`cadf3240 : tcl85t!Tcl_ExprObj+0x61c
0000007f`cadf3090 00000000`641f2acd : 00000000`ffffffff 00000000`00000003 000001ba`f48996e0 000001ba`aa6f4500 : tcl85t!TclEvalObjEx+0x3ad
0000007f`cadf3100 00007ff8`408cfd8b : 000001ba`f2a53390 000001ba`f2a98020 000001ba`b4760e70 00000000`64284790 : tcl85t!Tcl_EvalObjEx+0x1d
0000007f`cadf3140 00000000`641f11fc : 000001ba`f48996e0 000001ba`f48996e0 00000000`00001408 00000000`642bac7d : librdi_commontasks+0x1fd8b
0000007f`cadf31c0 00000000`64236238 : 000001ba`00000000 00000000`00000003 000001ba`f489f988 ffffffff`ffffffff : tcl85t!Tcl_ListMathFuncs+0x58c
0000007f`cadf3270 00000000`64234d5d : 000001ba`f48996e0 000001ba`aa92fb30 000001ba`aa6f8bf0 000001ba`00000000 : tcl85t!Tcl_ExprObj+0x1868
0000007f`cadf3870 00000000`641fd73b : 000001ba`aa6f8cb0 000001ba`ad5c11c0 00000000`00000000 00000000`00000001 : tcl85t!Tcl_ExprObj+0x38d
0000007f`cadf45f0 00000000`641f11fc : 000001ba`f48996e0 00000000`00000000 000001ba`9afcc030 000001ba`f489f7d0 : tcl85t!TclDumpMemoryInfo+0x5d6b
0000007f`cadf4660 00000000`641f218e : 00000000`00000000 000001ba`00000005 000001ba`f489f7d0 000001ba`9afcec4d : tcl85t!Tcl_ListMathFuncs+0x58c
0000007f`cadf4710 00000000`6425b660 : 000001ba`f48996e0 000001ba`9afcc030 000001ba`00000005 00000000`00000005 : tcl85t!Tcl_EvalEx+0x99e
0000007f`cadf4840 00007ff8`408f0333 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : tcl85t!Tcl_FSEvalFileEx+0x250
0000007f`cadf48f0 00007ff8`408ef7ec : 00007ff8`43554818 000001ba`abc68ec8 000001ba`f48996e0 00002f22`ac7b4012 : librdi_commontasks+0x40333
0000007f`cadf4b10 00007ff8`43091184 : 0000007f`cadf4eb8 00000000`00000050 0000007f`cadf4eb8 000001ba`f29c0000 : librdi_commontasks+0x3f7ec
0000007f`cadf4b40 00007ff8`43093f96 : 000001ba`f48996e0 0000007f`cadf4eb8 ffffffff`ffffffff 00000000`64293cf4 : librdi_common!hdi::tcltasks::task_manager::eval_in_tcl_throw+0x254
0000007f`cadf4e90 00000000`641f11fc : 00000000`6429948c 00000000`ffffffff 000001ba`f48996e0 00000000`642bac7d : librdi_common!hdi::tcltasks::task_manager::retrieve_except_msg_instance+0x4c6
0000007f`cadf5080 00000000`64236238 : 00000000`00000000 0000007f`00000002 000001ba`f489f510 ffffffff`ffffffff : tcl85t!Tcl_ListMathFuncs+0x58c
0000007f`cadf5130 00000000`64234fec : 000001ba`f48996e0 000001ba`aa946190 000001ba`f48996e0 00000000`00000000 : tcl85t!Tcl_ExprObj+0x1868
0000007f`cadf5730 00000000`641f2e8d : 00000000`00000000 000001ba`f48996e0 00000000`00000001 00000000`642848c0 : tcl85t!Tcl_ExprObj+0x61c
0000007f`cadf5780 00000000`642805ce : 000001ba`f48996e0 00000000`00000000 000001ba`aa6eeda0 00000000`00000003 : tcl85t!TclEvalObjEx+0x3ad
0000007f`cadf57f0 00000000`641f11fc : 00000000`00000000 000001ba`f488bb40 000001ba`f48996e0 000001ba`808c5046 : tcl85t!TclObjGetFrame+0x30e
0000007f`cadf5840 00000000`64236238 : 000001ba`00000000 00000000`00000003 000001ba`f489f498 ffffffff`ffffffff : tcl85t!Tcl_ListMathFuncs+0x58c
0000007f`cadf58f0 00000000`64234fec : 000001ba`f48996e0 000001ba`808c4f90 000001ba`b475b010 00000000`00000000 : tcl85t!Tcl_ExprObj+0x1868
0000007f`cadf5ef0 00000000`641f2e8d : 000001ba`f2a98020 000001ba`f48996e0 ffffffff`fffffffe 0000007f`cadf5fb0 : tcl85t!Tcl_ExprObj+0x61c
0000007f`cadf5f40 00000000`641f2acd : 0000007f`cadf6078 00000000`00000003 000001ba`f48996e0 000001ba`aa6fd870 : tcl85t!TclEvalObjEx+0x3ad
0000007f`cadf5fb0 00007ff8`408cfd8b : 000001ba`b4760e70 000001ba`f2a98020 000001ba`f2a98020 000001ba`feb71a50 : tcl85t!Tcl_EvalObjEx+0x1d
0000007f`cadf5ff0 00000000`641f11fc : 000001ba`f48996e0 000001ba`f48996e0 000001ba`9aae4020 00000000`642bac3c : librdi_commontasks+0x1fd8b
THREAD_SHA1_HASH_MOD_FUNC: 1a451dbce1f28c6996d6b6de92b3637b8a101c47
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 98c897566b3b5bb7e0491095f35b32c74cd84646
THREAD_SHA1_HASH_MOD: 763ce1f41a155ffa37f84e57f6af778c744ed776
FAULT_INSTR_CODE: c2048b4a
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: librdi_synth!HARTResynthMgr::~HARTResynthMgr+193
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: librdi_synth
IMAGE_NAME: librdi_synth.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 5dd6f5ff
STACK_COMMAND: ~4s ; .ecxr ; kb
FAILURE_BUCKET_ID: INVALID_POINTER_READ_c0000005_librdi_synth.dll!HARTResynthMgr::_HARTResynthMgr
BUCKET_ID: APPLICATION_FAULT_INVALID_POINTER_READ_librdi_synth!HARTResynthMgr::_HARTResynthMgr+193
FAILURE_EXCEPTION_CODE: c0000005
FAILURE_IMAGE_NAME: librdi_synth.dll
BUCKET_ID_IMAGE_STR: librdi_synth.dll
FAILURE_MODULE_NAME: librdi_synth
BUCKET_ID_MODULE_STR: librdi_synth
FAILURE_FUNCTION_NAME: HARTResynthMgr::_HARTResynthMgr
BUCKET_ID_FUNCTION_STR: HARTResynthMgr::_HARTResynthMgr
BUCKET_ID_OFFSET: 193
BUCKET_ID_MODTIMEDATESTAMP: 5dd6f5ff
BUCKET_ID_MODCHECKSUM: 1fb4007
BUCKET_ID_MODVER_STR: 0.0.0.0
BUCKET_ID_PREFIX_STR: APPLICATION_FAULT_INVALID_POINTER_READ_
FAILURE_PROBLEM_CLASS: APPLICATION_FAULT
FAILURE_SYMBOL_NAME: librdi_synth.dll!HARTResynthMgr::_HARTResynthMgr
TARGET_TIME: 2020-01-22T16:18:43.000Z
OSBUILD: 17763
OSSERVICEPACK: 475
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 256
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt SingleUserTS
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 1989-09-09 23:58:46
BUILDDATESTAMP_STR: 180914-1434
BUILDLAB_STR: rs5_release
BUILDOSVER_STR: 10.0.17763.1.amd64fre.rs5_release.180914-1434
ANALYSIS_SESSION_ELAPSED_TIME: 2b97
ANALYSIS_SOURCE: UM
FAILURE_ID_HASH_STRING: um:invalid_pointer_read_c0000005_librdi_synth.dll!hartresynthmgr::_hartresynthmgr
FAILURE_ID_HASH: {d51a85a6-6547-322d-6599-fdd75bc9f4d1}
Followup: MachineOwner
Any assistance that you can provide me with here would be great so I can compile my project using the latest tools
Thank you
Derek
