Can you guyz help me.??
Hi there,
I am trying to do a porject on Baugh_Wooley multiplier in sequential circuit.
With the last 1 weeks real hard work i came to end up with this code.
but now when i checked syntax i got the following error.
I dont know how to solve it....please help me....:(
I am attching the top level code also.
I am not sure it is legitimate to share the code or not, but i am really helpless. I tried a lot of ways...:(
thanks in advance.
Re: Can you guyz help me.??
You don't show the component declaration of white_cell but it seems you have a port called sin to which you are not making a connection.
Assuming this is what you are implementing: http://www.ece.uvic.ca/~fayez/courses/ceng465/lab_465/project2/multiplier.pdf
(page 4).
The white_cell has a port called si there which I think you name sin. You need to make a connection to that port.
(page 4).
Hi Muzaffer,
thanks a lot for pointing out that point. I was trying everything else but dont know how i missed that.
Now, there is no errors. My syntax checked successfully.
However, when i clicked for the VIEW RTL schematic, it does not show the circuits...may be i messed up with something.
I am actually planning to generate 8 or 12bit baugh-wooly multiplier, hence just started with 4 then will proceed.
I am attaching all of my codes. Please help me with this problems.
components code
last file.
I am trying to do it with sequential way. I am weak in clock issues.
I think i made mistake with that...please help me.
thanks
Did you run the synthesize step ? Also the generate post-synthesis netlist step? Check syntax isn't enough to generate the rtl view.
thanks for replying.
I ran the generate post-synthesis simulation model and it was successful. But when i clicked View RTL schematic then i got a bunch of warning and only got the top level view of the project.
but if i click on the top level model, i cant go inside that.
That's where my problem is...
Will you mind please telling me how can i generate post synthesis net list??
sorry for the ignorance...
Honestly that's not something I ever do. You need to upload a complete project directory so I can open and experiment.
dont know whats going on...but i cant upload the zip files in here...
anyone knows why?
thanks
hi there,
This is done for 4 * 4 bit....
but it works till 3 by 3 bit multiplication...whenever i am trying to do 4 by 4 multiplication it gives some error some results.
please advise me on this.
thanks in advance.
I want to add the project in here...please tell me how can i do this....
