Coding Guideline
https://www.xilinx.com/support/documentation/white_papers/wp275.pdf
is page 8 still valid for Vivado 2018.3 ? (Spartan 7)
@999068709169
As Richard says, both Version-1 and Version-2 give identical synthesis results, which are:
I agree with Richard that “making readable code” should be your selection criteria.
If you come from a software (C++, HLS) background then I suspect you will select Version-1.  However, if you come from a digital hardware background then you’ll probably choose Version-2.
My personal preference is Version-2 because it is a direct reference to the digital combinational logic found in the LUT2 resulting from synthesis.  -and, since we are using VHDL (a hardware descriptive language) then we should be “thinking hardware” as we write our code.
Cheers,
Mark
Yes. That example is just a general coding statement that is pretty valid for all devices.
Do you have a specific question?
@richardhead
Xilinx recommends version1 or version2?
Version 1
if rising_edge(clk) then
    if (a ='1' and b = '0') then
        output <= '1';
    else
        output <= '0';
    end if;
end if;
Version 2
        output <= a and (not b);
end if;
Hi @999068709169 ,
version 1.
hemangd
@999068709169
Those are functionally identical and will give identical synthesis results.
The paper talks more about Set and Reset of the built in flops. Your code example does not.
Code with the style you find (and others will find) most readible. Synthesis is very good today and its much better to have a readible style than "tool friendly" style from 2007.
@hemangd you are suggesting version 1 whereas @richardhead says "does not matter just write readable code". Do you have some explanation?
@999068709169
Cheers,
Mark
