Coding style for Inferring DSP pattern detection?
Is there a (VHDL) coding pattern in Vivado 2019.2 which will allow DSP pattern detection implementation to be inferred?  The alternative of explicitly instantiating the DSP48E1 is tiresome and somewhat error prone.
I've tried the attached, but without luck:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity test_dsp is
    Port (
        clk_i : in std_ulogic;
        a_i : in signed(17 downto 0);
        b_i : in signed(24 downto 0);
        c_o : out signed(42 downto 0);
        ones_o : out std_ulogic
end test_dsp;
architecture arch of test_dsp is
    signal a_in : signed(17 downto 0);
    signal b_in : signed(24 downto 0);
    signal ab : signed(42 downto 0);
    signal ab_result : signed(42 downto 0);
    constant MASK : std_ulogic_vector(42 downto 0) := (
        42 downto 16 => '0',
        15 downto 0 => '1');
    function pdetect(
        mask : std_ulogic_vector; pattern : std_ulogic_vector)
        return std_ulogic
    is
        variable result : std_ulogic := '1';
    begin
        for i in mask'RANGE loop
            result := result and (mask(i) or pattern(i));
        end loop;
        return result;
    end;
begin
    process (clk_i) begin
        if rising_edge(clk_i) then
            a_in <= a_i;
            b_in <= b_i;
            ab <= a_in * b_in;
            c_o <= ab;
            ones_o <= pdetect(MASK, std_ulogic_vector(ab));
        end if;
    end process;
end arch;
Re: Coding style for Inferring DSP pattern detection?
Thank you, that example code gave me the direction I needed.  It seems that a very direct style of coding is needed, and it seems it's enough to write
all_ones <= ab(RANGE) = ONES_MASK;
all_zeros <= ab(RANGE) = 0;
where ab about to be assigned to the P register, to get the required inference to synthesise DSP pattern detection.
I've checked both with and without accumulator, the example code below now synthesises to exactly one DSP and one LUT (for the final ovf_o computation).  Perfect!
library IEEE;
entity test_dsp is
    port (
        c_i : in signed(47 downto 0);
        p_o : out signed(47 downto 0);
        ovf_o : out std_ulogic
end test_dsp;
    signal c_in : signed(47 downto 0);
    signal abc : signed(47 downto 0);
    subtype OVF_RANGE is natural range 47 downto 16;
    constant ONES_MASK : signed(OVF_RANGE) := (others => '1');
    signal all_ones : boolean;
    signal all_zeros : boolean;
begin
            a_in <= a_i;
            b_in <= b_i;
            c_in <= c_i;
            ab <= a_in * b_in;
            p_o <= abc;
            all_ones <= abc(OVF_RANGE) = ONES_MASK;
            all_zeros <= abc(OVF_RANGE) = 0;
        end if;
    end process;
    abc <= resize(ab, 48) + c_in;
    ovf_o <= '0' when all_ones or all_zeros else '1';
end arch;
A good question
this doc, page 98
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug901-vivado-synthesis.pdf
uses the pattern detect to do a rounding,
dont know if its of any use, I'm interested in your results,
library IEEE;
entity test_dsp is
    port (
end test_dsp;
begin
            a_in <= a_i;
            b_in <= b_i;
            c_in <= c_i;
            ab <= a_in * b_in;
            p_o <= abc;
        end if;
    end process;
end arch;
