zafvagos
Coe File creation
I am intending to write a .coe file for a Memory. In case of non-used addresses, how should I declare it through the .coe file?
vsrunga
I think .coe should fill the full depth of the RAM, you may write zeros in un- wanted locations.
vsrunga
