ComMsgMgrException: invalid index for scalar '%s': Invalid c_string in format.
I've found what appears to be an internal error in Vivado 2019.1 synthesis. The message occurs when trying to index a non-arrayed signal with multidimensional indices in SystemVerilog. In the attached TAR are three top-level modules (test_1d.sv, test_2d.sv and test_fixed.sv) and an interface (test_ifc.sv). In the latter is the signal definition:
logic vld_in;
In test_1d.sv, the signal is erroneously referenced with one array index:
always_ff @(posedge ifc.clk) begin
   vld[0] <= ifc.vld_in[0];
end
If I try to synthesize this, Vivado gives a decipherable error message (though it'd be better if it said "ifc.vld_in"):
ERROR: [Synth 8-373] invalid index for scalar 'ifc_vld_in_vld_in' [/home/tcl/invalid_index/test_1d.sv:12]
In test_2d.sv, the signal is erroneously referenced instead with two array indices:
   vld[0] <= ifc.vld_in[0][0];
end
This outputs an internal exception and a cryptic message which gives no clue where the error lies, rendering it useless:
ERROR: [Synth 8-373] invalid index for scalar '%s'
I'd like to have this test case forwarded to the Vivado development team for fixing. The three top-level modules can be synthesized with the following commands:
vivado -mode batch -source synth.tcl -tclargs test_1d
vivado -mode batch -source synth.tcl -tclargs test_2d
vivado -mode batch -source synth.tcl -tclargs test_fixed
Thanks for your help!
Re: ComMsgMgrException: invalid index for scalar '%s': Invalid c_string in format.
Thanks for pointing out the error.
I could reproduce the issue at my end and will report it to development to be fixed in a future release.
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
-Shreyas
