Could not find cell 'U0' within module
I'm getting Vivado General Synthesis "Could not find cell 'U0' within module" errors associated with a few Vivado IP Catalog cores.  I have many more IP Catalog cores in the design for which there are no errors.  An example error is,
[Designutils 20-1275] Could not find cell 'U0' within module 'GTX_Clk_Gen' for instance 'emc/ecg'. The XDC file c:/Users/rbackhus/Documents/GEOSTAR/FromLinux/GEOSTAR_Demonstrator_Control/GEOSTAR_Demonstrator_Control.srcs/sources_1/ip/GTX_Clk_Gen/GTX_Clk_Gen_board.xdc will not be read for this cell.
I tried regenerating the core outputs and that didn't change anything.  These errors are from a Xilinx tool synthesizing Xilinx IP Catalog generated cores.  None of this is mine so I'm really sure what the problem is here.
This is Vivado 2014.4 running on 64 bit Windows 7.
Any ideas?
Re: Could not find cell 'U0' within module
After a week working this problem the web case engineer concluded that when one builds a core out of context, black box attributes are generated which are to be pasted into the source with the component declaration.  Then when I deselected the out of context selection, I failed to remove the black box attributes from my code.  Nevertheless, the clock wizard put the black box attributes in the vho file whether the clock was built out of context or not.  In that case I just removed the attributes even though they were included in the vho file.  All the critical warnings went away.
I misspoke above.  These arn't errors.  They are critical warnings.
Are you generating the IPs in OOC flow?
Vinay
Can you open the elaborated design and compare the connectivity of this failing ip instance with that of passing one? Are all the inputs to the ip instance connected properly?
Also open synthesized design and check if the tool by chance renamed the U0 cell to something else.
Deepika.
Deepika.
I generated all my cores out of context but then switched them all back out of OOC and am now doing "General Synthesis", I think it is called where the project synthesis builds all the code including the cores.
Yes, I checked that.  The ports are properly connected on all my cores.
Can you apply DONT_TOUCH constraint on the problematic IP instance and see if it helps? Below is the xdc syntax
Example: set_property DONT_TOUCH TRUE [get_cells inst]
Deepika.
Deepika.
