Create sixteen 80-bit registers
Greetings,
I am trying to create sixteen many 80-bit registers and I don't want to instantiate the register block 16 times. So I made the following.  Looking at the waveform, it seems only create one 16-bit register.    Could anyone guide what is the issue of the code or how this suppose to be implemented?    Thanks in advance.
CH
-- code start
-- signal declearation
type dataregoutput_type is array(0 to 15) of std_logic_vector(79 downto 0);
signal dataregout : dataregoutput_type;
-- functional code
gen_dataregen: for i in 0 to 15 generate
dataregen(i) <= (addren(2) or initregout(0)) and decoder_4_to_16_out(i);
U_Register: entity work.Register(Registerbhv)
generic map(width => 80)
port map(
CE => dataregen(i),
D => datain,
Q => dataregout(i),
Clock => clkctrl,
Reset => Reset);
end generate;
Re: Create sixteen 80-bit registers
look up arrays ,
and the generate statment, as in for i in 0 to 15 generate
Mentor
Mentor
your code looks more or less OK,  you should load the synthesized design in Vivado, and then check the schematic to see if the registers have been created.
