Critical warnings [Synth 8.5559] and [Synth 8-3352] with Vivado 2016.3
When migrating form Vivado 2016.2 to 2016.3 I got suddenly 6944 instances of the following critical warnings
CRITICAL WARNING: [Synth 8-5559] multi-driven net I1 is connected to constant driver, other driver is ignored
CRITICAL WARNING: [Synth 8-3352] multi-driven net I1 with 1st driver pin 'gmem_controller_insti_6/i_212/O'
These critical warnings are generated at technology mapping and they refer to some vhdl unit that I wrote myself.
The old project is still working well.
Re: Critical warnings [Synth 8.5559] and [Synth 8-3352] with Vivado 2016.3
HI @m.alkadi
Do you not get these warnings in 2016.2?
Please show the corresponding code.
Aside: This AR explains the common reason multi driven warnins arise.
http://www.xilinx.com/support/answers/60013.html
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
Hi nagabhar,
I do not get any critical warning with 2016.2.
I cann't determine which part of my code causes the problem with 2016.3. The critical warnings are generated at technology mapping and the net names are not really helpful.
Unfortunately I'm not allowed to post the code. Anyway I'm using it since 2 years and it worked perfectly with all previous versions.
HI @m.alkadi
We need a test case to understand whats changed in 2016.3 . If you have access to Xilinx Service request portal , please rise an SR.
From warnings itself , it seems net I1 has two drivers , a constant and  'gmem_controller_insti_6/i_212/O. after synthesis , you can check the netlist for "gmem_controller_insti_6/i_212" and see what its output is driving.
Bharath
@m.alkadi
Can you verify the net connection by opening the synthesized design? Search for the net mentioned in the warning "'gmem_controller_insti_6/i_212/O"
We expect the results should be better or same with the new release, if this is not the case I will raise a CR after reproducing the issue.
Anusheel
Helpful answer -> Give Kudos
