DAVIDN_OVERLOAD Overloaded load : 65535 < 0.000000 max value is
Using ISE 14.6, I'm getting this during synthesis. Same design works on a spartan 6 slx45, but sits there for hours after printing the messages using a spartan 3 / 1400.
Anybody saw this before?
*                       Advanced HDL Synthesis                          *
Analyzing FSM <FSM_1> for best encoding.
Optimizing FSM <S_state/FSM> on signal <S_state[1:2]> with gray encoding.
 State | Encoding
 00    | 00
 01    | 01
 10    | 11
 11    | 10
Analyzing FSM <FSM_0> for best encoding.
DAVIDN_OVERLOAD Overloaded load : 65535 < 0.000000 max value is 0 : -458792496 < 0.000000
DAVIDN_OVERLOAD Overloaded load : 65535 < 0.000000 max value is 0 : 1693049120 < 0.000000
DAVIDN_OVERLOAD Overloaded load : 65535 < 0.000000 max value is 0 : -458768592 < 0.000000
Re: DAVIDN_OVERLOAD Overloaded load : 65535 < 0.000000 max value is
Try using new parser for synthesis using -use_new_parser in more command line options of synthesis properties.
Deepika.
Deepika.
Deepika.
Deepika.
