Dealing with .txt extension file in VHDL
Hello!!!
I am trying to implement a vhdl module which will have input as .txt file which i shall read and then the contents of that .txt file should be loaded in Block RAM's of XC5LX110T fpga DDR.
I am newbie in hdl language plz help me on this.
Re: Dealing with .txt extension file in VHDL
The Fine Manual to Read in this case is UG627 (v 11.3). Page 176 has a relevant example.
thanks I think it will work for me.
Instructor
Instructor
For those who are not on v11.3 of UG627, search the file for "Initializing Block RAM (External Data File)"
-- Bob Elkind
SIGNATURE:
Summary:
